Question about Hoover HTC243 Top Load Washer
Hoover 550 front door locked, can't get the clothes out
The lock on my Hoover Nextra front loader washing machine snapped off when attempting to open the door on completion of wash. Can this be repaired
if it.s the inner door lock catch, that attached to the front door handle
yes it can be replaced, take photo and model number of machine
order from washing machine repair shop. or download manual from malefactors site for correct part number, ,or if you need a repair engineer ring for a quote first, how much will it cost to replace my hoover inner front door catch, good luck
Oct 05, 2016 | Hoover AAA160 Front Load Washer
Hoover washing machine door lock
I hope yr going to replace it, not run the machine without the lock. The lock is for safety, if a kid tries to grab clothes when it is spinning it can twist an arm off. So there is a safety concern.
Sep 01, 2014 | Hoover Washing Machines
How do i open my hoover eco technology door when it wont open and comes up with the code E15
That means a sevies tech has got to come out an unlock
it the main board is bad these front loaders
are bad about this they will lock up all your
cloths
Jun 13, 2014 | Zanussi ZWD1470W Front Load Washer / Dryer
Hoover nextra washing machine door wont lock / cycle start
sounds like the door lock mechanism. if this cannot signal it has engaged, to the board, no other function will work (you don't want the washer going with the door open, trust me :) )
Nov 08, 2013 | Hoover Nextra 160 HNWF 3137 Front Load...
Hoover Nextra HNWF 3135 door will not lock
1) test the switch door, you do not have error code.
see the video, and replace for defective switch, or loose wires or broken, or burn.
God bless you
Jun 28, 2012 | Hoover Nextra HNWF 3135 Front Load...
My Hoover 1600 AAA Vision HD 8 kg. Washing machine will not open the door after programs are ended. I can run all programs, but when finished the door will not unlock! What is wrong? I dont have the...
try pushing the door really hard if it opens check the door seal is on properly sometimes they pull off when removing clothes they can get trapped in hinges
Jan 17, 2011 | Hoover AAA160 Front Load Washer
How do I fit a Hoover washing machine door interlock? I have to part.
Hi.
You need ro remove the door seal from the front of the washer, this will then give you access to the door lock.
Good luck
Jan 14, 2010 | Hoover H160E Front Load Washer
Hoover washing machine front loader, has power, have reprogrammed, but still won't start. Door lock light won't come on. For the last few washes before it quit altogether, the time lapse between pressing...
Hi brennanjodi
I think your door interlock needs replacing. Turn off the power undo the front of the door gasket and that will get you to the lock mechanism. They're about £20 to replace.
Adrian
May 14, 2009 | Hoover PE235 Front Load Washer
Hoover HTC243 Top Load Washer Logo
18 people viewed this question
Top Hoover Washing Machines Experts
peter gittos
peter gittos
Gerry Harvey
Gerry Harvey
Poppa Maddo
Poppa Maddo
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
