Galaxy Radios DX-44V 40-Channels Base CB Radio Logo
A
Anonymous Posted on Apr 10, 2014
DX -44V no tx. Replaced defective 2sc1969. Radio keyed up then power started to drop and the final got hot. Any idears
Mike Charette
Level 3:
Genius:
  • Galaxy Radios Master 1,847 Answers
  • Posted on Aug 09, 2014
Mike Charette
Level 3:
Genius:
Answers
1847
Questions
Helped
490600
Points
2212
Replace final and driver.If it happens again your power is set to high.
4 Related Answers
Mister 44
Jim Verge
  • 35 Answers
  • Posted on Apr 12, 2010
SOURCE: galaxy 44v no transmit or receive
Try replacing TR41 (2SA473).
Also check TR40 (2SC945), D78 (7.5 volt Zener Diode), and D79 (KB 262).
[email protected]
Anonymous
  • 10 Answers
  • Posted on Jan 13, 2011
SOURCE: I would like to know
http://www.cbtricks.com/radios/galaxy/dx44v/index.htm owner manual
Anonymous
  • 98 Answers
  • Posted on Apr 11, 2011
SOURCE: dx 44v diplay out
Sounds like it blowed...check fuse, power wires.. if it got hooked up backwards it will blow a diode in back of radio. Take off cover change all black diodes with a solder gun.
anymhz
AnyMHz.com
  • 500 Answers
  • Posted on Nov 27, 2011
SOURCE: were is the keying final an a DX cb radio
There is no keying FINAL? there is a diode under the mic connector that controls TX/RX keying up.. but if your talking about the Final RF transistor its a 2sc2312,or 2sc1969 both they discontinued, so places still have them. they should be under $6.. but all radios new, are using MOSfet's.. there is a process to do the change on radios that had the analog transistors.
You could send it in to us and we can fix it.
We do not charge to look at any radio -no bench fees-..
Let me know Ill get you any info that you need.
Galaxy dx-44v wont power on
check near the rear of the radio.. around the power input connection and the audio transformer there should be a 1n4001 diode.. check it for a short. replace it if it is.. and it should power up.. also in the same area check for any shorted traces.. on the circuit side.. also
on the sides of rci main board radios near the bracket screws theres a transistor voltage regulator.. make sure its connected to the board.. sometimes they come loose.
Were is the keying final an a DX cb radio
I would like to replace the stock 2SC1969 bipolar transistor with a ERF2030 mosfet transistor in a Galaxy 93T.Can anyone tell me if any caps need to be removed on the amp board since C203 and L33 are not...
The radio you listed "Galaxy DX-93T Base CB Radio" utilizes a 2SC2290 final transistor. This is not a T220 2SC1969 and you cannot install an ERF2030. This is a round and white looking transistor. Replace it with only the same transistor.
I have a galaxy 44v it transmits on fm but receives on am what can i do to fix this problem
Replace the AM final, then make sure your antenna is tuned to lowest SWR to prevent the final from burning out again.
My rf gain is out where do I find one, Mic gain/ Rf same knob on my 44v 1kb mic / 1ka rf gain dual knob vaiable
They can be ordered just google cb shop temple, tx on highway 95 they have parts and will ship to you. give em a call with part desciptions.
Quiet Galaxy DX 44V
Sounds like you have lost a final or a driver transistor if so a shop or reputable repairman is your best answer. You should also have him check your cables and SWR on your antenna system as well as check for loose grounds. Sounds like you had a high SWR and blew out a final transistor. But it could be as simple as a loose component or cold solder joint in the radio. Get professional help.
5helpful
2answers
How to adjust frequency on transmit??? Galaxy
hELLO THERE
hERE IS SOME MODIFICATIONS FOR THIS RADIO
Galaxy Mods DX 2527 - VR 1....AM/FM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 7....SSB Carrier Balance, VR 8....RF Meter, VR11...Driver Bias, VR12...SSB ALC, VR13...Hi Power, VR14...AMC, VR15...AM Low Power, VR16...SSB Low Power, VC 1....10.240, VC 2....10.240. DX 2517- VR 1....AM/FM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 5....FM Deviation, VR 6....SSB Carrier Balance, VR 7....TX Offset, VR 8....CW Beep Level, VR 9....RF Meter, VR10...Final Bias, VR11...Final Bias, VR12...Driver Bias, VR13...SSB ALC, VR14...AM/FM High Power, VR15...AM Modulation Meter, VR16...AM Modulation, VR17...SSB Power, VR18...AM/FM Low Power, VR601..13.8 Volt Power Supply. DX 22B- VR 1....AM/FM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 7....SSB Carrier Balance, VR 8....RF Meter, VR11...Driver Bias, VR12...SSB ALC, VR13...High Power, VR14...AMC, VR15...AM Low Power, VR16...SSB Low Power, VR21...TX Offset, VC 1....10.240, VC 2....10.240. DX 11B- VR 1....AM/FM S-Meter, VR 2....SSB/CW S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 5.....FM Deviation, VR 7....SSB Carrier Balance, VR 8....RF Meter, VR10...Final Bias, VR11...Driver Bias, VR12...SSB ALC, VR13...AM/FM High Power, VR14...AM Modulation, VR16...CW Tone Level, VR20...Final Bias, VR21...TX Offset, VR601..13.8 Volt Power Supply, VR803..AM/FM Low Power. DX 77HML, DX 88HL, and DX 99V- VR 1....AM/FM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 5.....FM Deviation, VR 7....SSB Carrier Balance, VR 8....RF Meter, VR10...Final Bias, VR11...Driver Bias, VR12...SSB ALC, VR13...AM/FM High Power, VR14...AM Modulation, VR16...AM/FM Low Power, VR20...Final Bias, VR21...TX Offset.
Unmarked VR in R189..AM/FM Medium Power for DX 77HML only. DX 33HML, DX 44V, DX 55V, DX 66V, and DX 73V- VR 1....AM/FM S-Meter, VR 4....AM/FM Squelch Range, VR 5.....FM Deviation, VR 8....RF Meter, VR12...Low Power AM Modulation, VR13...AM/FM High Power, VR14...High Power AM Modulation, VR16...AM/FM Low Power.
Unmarked VR in R188..AM/FM Medium Power (DX 33HML only)
Unmarked VR in C139..Med Power AM modulation (DX 33HML only) DX 949,DX 959- VR 1....AM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM Squelch Range, VR 6.....SSB Carrier Balance, VR 7....TX Offset, VR 9....RF Meter, VR10...Final Bias, VR12...Driver Bias, VR13...SSB ALC, VR14...AM High Power, VR15...AM Modulation Meter, VR16...AM Modulation, VR17...SSB Power, VR18...AM Low Power, VC1....10.240. DX 2517 and DX 2527-
Symptom:Buzzing or motorboating sound in either the transmit or receive.
Problem: TR602 is oscillating
Cure: Replace C602 with a .01uF cap {Cap is located in the power supply board}.
RG 66,99,DX2517 Replace Q54 2SB754 60watt 7A with a higher power 2SB817 100 Watt 12A. Derating of this component will cool operation, provide better voltage stability,decrease wobble, allow voltage increase to 14.5 volts comfortably. (replace 10 volt caps in this section of the radio to a minimum of 16 volts before increasing supply voltage to this level)and provide faster swing rise time, Replace Q37 2SA473 to a 2SA1012-0 or ECG153 this will improve the clarity and volume of the modulation and it will also run a lot cooler.
Top Galaxy Radios Radio Communications Experts
eradiostore
eradiostore
 Grubhead
Grubhead
Are you a Galaxy Radios Radio Communication Expert? Answer questions, earn points and help others
