Windows 7 new monitor will not install from CD can't find ASCDDMI.DLL
SOURCE: Msvcr71.dll cannot be found
hiya
please goto here and download the file and copy it to your windows\system32 directory
hope this helps
Rik
SOURCE: xolehlp.dll problen
You can go to the following link and download the file
http://www.dll-files.com/dllindex/dll-files.shtml?xolehlp
1. save the file on the desktop
2. Right click on the saved file and extract it the following location
c:windows/system32
3. Restart your computer and try installing sql again
Best of Luck
Proton
SOURCE: iertutil.dll
It might have been caused due to some problem in internet explorer 7(IE7)
Try to uninstall IE7. You can use the following
method if it does not show up in add/remove programs.
Reference: http://support.microsoft.com/kb/927177
NOTE:
IF
SP3 was installed AFTER IE7, you MUST uninstall SP3 first, uninnstall
IE7, then re-install SP3. If SP3 is NOT installed, simply follow the
procedure as shown.
Step 1:
Make hidden files and hidden folders visible
Click Start, and then click My Documents.
On the Tools menu, click Folder Options.
Click the View tab.
In the Advanced settings list, under Hidden files and folders, click Show hidden files and folders, and then click OK.
Step 2:
Uninstall Internet Explorer 7
To uninstall Internet Explorer 7, follow these steps:
Click Start, and then click Run.
In the Open box, type %windir%\ie7\spuninst\spuninst.exe, and then click OK.
Follow the wizard instructions to uninstall Internet Explorer 7.
SOURCE: i have the same regsvr32 wintrust.dll error code 0x80070005
- Double click on the clock in the taskbar and make sure the system clock is set correctly.
- Disable Zone Alarm
- Register softpub.dll using the regsvr32.exe tool.Click Start, and then click Run.
- In the Open box, type regsvr32 softpub.dll and then click OK.
- Do the same for the following regsvr32 wintrust.dll, regsvr32 initpki.dll, regsvr32 MSXML3.dll.
- Restart Windows Live Messenger.
If you are still unable to fix Windows Live Messenger your computer might be infected, I recommend you Download registry cleaner to fix your errors and speed up your computer.
SOURCE: windows 7 - blue screen error: ati2dvag.dll
try to re-install driver of your video card , it should be supported by windows 7
