SOURCE: maytag side by side freezer works, fridge does not
the heat is from the condensor keeping the door from frezzing shut it is normal but you need to adjust the food compartment contorl it might say for a for a coler frezzor turn up then you do and the food compartment gets warmer all it is is a air baffle to alow more cold air into the food compartment turn the cold control half way its the one that has off on it and then turn the other control to a lower number to make more cold go into the food compartment
SOURCE: Maytag MZD2766GE side by side, fridge not getting cold.
Your timer for the automatic defrost is defective. Replace it. If you thawed out the back of the freezer, this could be good for 3-7 days and it will freeze up again. I had the same trouble.
Bobby Johnson
SOURCE: "maytag plus wide by side is not getting cold enough"
The defrost thermostat is failing on these machines as well as the adaptive defrost control.
The compressor start relay is on recall from Maytag also.
SOURCE: Maytag wide by side MZD2667HEW freezer works fridge does'nt
Was it the damper control you replaced and it's still not adjusting the vent(damper)?
And is the cold air from the freezer being blown through the vent by the fan in the freezer.
The circuit board mainly controls the defrost timing and the fans. I don't know that it would solve your problem.
SOURCE: I have a Maytag MSD2456DEB side by side
freezer side check fan working check damper to ref. side.
Check
out these tips...they can help you figure out what is going wrong
with your refrigerator and why it is not cooling
Refrigerator
not Cooling
or Fridge not Cooling
How to Defrost Refrigerator Defrost
Timer Problem
Water
Running in refrigerator
from Freezer
Refrigerator
or Freezer not Cooling or Getting Cold
heatman101
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
