SOURCE: PCL XL error
try reinstalling the pcl 6 driver if that doesnt work try another document or it could also be the jet direct card.
SOURCE: when trying to print to
try loading a pcl5 driver instead of the pcl6. pcl xl is hp's pcl6 and some times has problems.
FIXED: PCL XL error when printing to a HP printer
I fixed this problem by installing the KB948046 Hotfix from Microsoft (thanks to Brent Follett from forums11.itrc.hp.com for pointing me in the right direction).
To download and install this hotfix, search for “hotfix KB948046” or go to http://support.microsoft.com/kb/948046 and click on “view and request hotfix downloads”.
You will be prompted for an email address, the URL for the hotfix together with a password will be emailed to that address.
Install the hotfix and reboot the system. The problem was fixed for me at this point.
I tried to print before rebooting, but that did not fix the problem, a reboot is essential.
More information:
I encountered this problem on a HP 2605 (laserjet) printer (HP2605) that was shared from a Windows Small Business Server 2003 with Service Pack 2 (SBS SP2).
When printing from networked machines the error was printed out on the printer. After installing the KB/948046 hotfix on the server only and rebooting the server, the problem was fixed.
I also installed other updates on the server before installing the hotfix using Microsoft Update.
For more information visit http://www.brightvisions.co.uk
If you don’t have a website yet, visit http://www.set8.net and if you have a website list it on http://www.searchourworld.com
I hope you found this useful and this fix works for you. Happy Hunting!
SOURCE: PCL XL error in hp laserjet 3055
information about the cause:
PCL XL error pages that print from an HP LaserJet 1200, 1300, 2200, 2300, 3200 or 3300 series product when a PCL 6 printer driver is in use typically indicate a communication issue. Sometimes this issue is caused by an incompatibility between the Enhanced XL language and the software application.
You can find the solution for this error here:
(It's a long instruction page, I advise to copy the sections that refere to your OS to a separate document, so you don't miss any step)
URL to HP service page:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=1161389&prodTypeId=18972&prodSeriesId=1161389&objectID=bpl10637
