The motor runs fine but the rotating head does not rotate
Usually this is a clutch problem, the clutch is under the drum and when it engages turns the drum which turns the drive shaft which turns the trimmer head. If the drum is not turning than it is the clutch, if the clutch is turning the drive shaft could be broke, if the drive shaft is not broke than the problem would be in the gears of the trimmer head.
Had this on my strimmer also. What it was was the drive cable that runs down the top shaft was not seated properly. Just fiddled with it and pushed it back into the head assembley then reconnected the lower shaft and it worked ok
