for your black cartridge watch this video
http://inkfilling.net/instructions-on-how-to-refill-hp-336-c9362ee.html and for color that http://inkfilling.net/instructions-on-how-to-refill-hp-343-c8766ee.html
1. Service menu: Menu -> Scan -> Copy -> Scan 2. Select "TEST MODE" 3. Select "[8] ETC.." 4. Select "[4] EEPROM CLEAR" 5. Select "[1] INK COUNT" 6) Press the [OK] key. 7) Press the [Stop/Reset] key (returns you to the TEST MOD sub-menu)) 8) press the [ON/OFF] key (which resets the printer)
The error code means "Ink Detection Waste Ink Tank Full". This means that the ink pad needs to be replaced. Also, dont forget to set the eepron counter to 0. Please follow the steps:
Press
ADITIONAL FUNCTIONS SCAN COPY SCAN scroll to TESTMODE scroll to PRINTER TEST scroll to EEPROM CLEAR and the press the numeric key 3 or and keys. Select INK COUNT, and then press the numeric key 0 or and keys to reset the waste ink capacity. Press the [Stop/Reset] key and then the [ON/OFF] key to end the test mode.
I tries to replicate this error in my printer and I was able to aolve it with the above mentioned steps.
Manual Reset procedure Waste Ink Tank for Canon MP390:
Start with printer on, press additional functions, Scan, Copy, Scan. Now you should be in service mode.
Select Test mode (must be the last available selection).
Select #8 Printer Test, it will start cleaning then it will come up with some other option: push the + or - button until it says 8-3 then hit the select button
The menu will now say EEPROM Clear
Select Ink count which is option (0) and press set
Press Stop/Reset Followed by the power button and then wait for it to restart.
