SOURCE: hydrostat trans starting to make moaning noise stops pulling
it may be full of dirt etc and has soaked up most of the oil inside the case, if the axle seals are worn and the selector shaft seal is worn I would say that is the problem, if that is the case you may be up for a new trans as I have done a transaxle just recently and the damage inside was extensive and expensive.
you will have to remove the trans and seperate the trans case for inspection
Hope this helps
SOURCE: tractor wont drive or engage electric clutch.
It thinks you aren't sitting on the seat.
There are 2 wires and a switch under the seat. The plug may have come off, the connections might be bad, or the switch might be bad.
SOURCE: Craftsman lawn tractor mower,
The belt is probably slipping because it is not tight enough. look by the belt, inside there is a little spring, you may half to tighten it.
SOURCE: Mower will not move.
It is very likely that your belt is not on right. Check your manual to see it it is on right.
SOURCE: craftsman ZTS 7500 dies when engage blades or when engage transmission
Replaced arm switches. Now when I engage the blades it dies. Checked seat switch.
