There is a white vertical band from top to bottom of screen about 3 inches wide...the restvof the screen shows good picture
Good luck with this. If it is under warranty, Sharp will take forever to do anything about it. I had this issue and Sharp wanted pictures of the problem, Pictures of the serial and model number and the receipt. I sent it to them 6 months ago and never heard anything back. If it is not under warranty, this is a major repair and it may cost more than a new television.
SOURCE: Sharp aquos hdtv has sound but shows a white screen
yes and no. That particular tv you have is done for, but if you just purchased it 6 months ago, you are still within you 1 year warranty with sharp. they will ask you to take it to a authorized service center and you need to follow through with the process. about a week or 2 will pass and the service center will deem the unit unrepairable and sharp will replace it if they cant solve the problem. give em call..good luck 2u
SOURCE: Screen damaged from fall, colored vert lines on left side from the damge
Unfortunately the LCD panel would need to be replaced. Even if there is not any signs of damage to the outside portion of the panel, one of the inner screens may have been fractured. I am not sure if the panel would be available because if i'm not mistaken Sharp just started making replacement panels.
SOURCE: screen of aquos lcd 42
You have a bad decoder board my friend and the replacment will have you digging into thy pocket book to grab out $150 bucks for a new board. Now if this is under warranty you can sure take it in for a free repair @ a autherised service center for the sharp. Butthis is a bad decoder board inside the unit.
Thanks and please do rate your solutions today.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
SOURCE: line accross top of the screen with flashing black and white boxes
Go to menu and settings and look for OVERSCAN and set this to on and hey presto no more white lines no matter what ratio your in.
SOURCE: I have dark vertical streaks on my screen.
If you can open your LCD than open & clean all connector & refit properly.
