Tom tom go 630 comes on and shows t&c and if i press i agree, it switches off?
SOURCE: Tom Tom 910 Green light but does not come on.
Remove battery and disconnect from power for 5 minutes, also remove map card, this will reset the device. Try it out
click;
Repair4GPS: How to Clean, Upgrade, Repair, Mod, Disassemble a GPS ...
see here
http://www.tomtom.com/lib/doc/legal/lw/LW-English-US%20CAN.pdf
To only way you can fix it is taking apart the Tom Tom, checking if the flat ribbon cable and connector to the screen are well in place and eventually replace the display ($80 on Ebay).
Unfortunately this will invalidate the guaranty, and you risk to damage your GPS if you are not a really experienced DIYer. Tom Tom offer one year full guaranty on all their receivers.
Contact Tom Tom and get it repaired:
Support URL: http://www.tomtom.com
Support Phone Number: 978.287.9555
Support Email Address: [email protected]
Hope this may help;
DON'T FORGET TO RATE:
SOURCE: tomtom one won't come on
Help!! when I turn on my (tomtom one) it go's to a screen (with drums beating) not the screen where it boots up... the it telles me on to disconect to my pc.... well, I'm not on the pc I'm in the car... help?
SOURCE: When I switch on my TomTom, SD card has a red cross?
This problem is due to the memory card not containing the TomTom application or map. To update the application onto the memory card, Connect the device to your computer. Open the TomTom Home application. Click on 'Update My Device'. This should then install the application onto the SD card. Alternativly, you could perform all the steps above without the SD card in the device, this will install the application onto the internal memory. Note: you may also need to install your maps, voices, etc after you update.
