SOURCE: Memory Card Error
format the memory card by using low level format in your camera itself.
it must work. check out and reply the rating
SOURCE: error messages "cannot display image" or memory card error, etc.
Try a different SD card to start.
SOURCE: my pentax k100d has a memory card error
Trun the camera off and remove the batteries. Leave it for at least a minute before inserting the batteries. Put the car in and turn the camera on.
The firmware in these cameras can get confused. Removing the batteries for a minuite or two will allow the camera circuits to discharge and so it will reset from start when powered-up again.
If this does not work then the camera may need to be sent away for repair. This need not be expensive it could be as simple as re-programming the camera. (Their program memory is writeable and so it can be accidentally altered under certian circunstsances. It may be possible to do this yourself using the downloadable firmware upgrade, but I would let someone else try thet first!)
However, it is just possible that the new card is also faulty!
Check the cards in your PC by obtaining a SD card reader to allow you to plug it directly into your PC.
For reference I would always recommend inserting and removing memory cards with the camera turned off. I would also use the SD card reader to load the images into the PC. Unplugging devices form the USB port can be harmful to some devices. Check the bottom right of your PC screen for an 'safe unplug' icon when things are plugged in.
SOURCE: memory card error
put the card in your computer, right click on the disk and do a quick format. Then remove and try in your camera again.
SOURCE: Memory Card Error after Formating memory card
instead of quick format, use the full format. Then put back in your camera and format again with the camera.
