For some reason the Keurig B70 we now have will a puncture a huge hole in the top and grounds will spill out and get into the coffee cup. Also coffee with spill out from spots other than the exit hole at the bottom and makes a real mess. It doesn't happen with every brew but probably every 4th or 5th cup. Cleaning it doesn't seem to matter. We had an earlier model for a number or years and this never happened.
SOURCE: My Keurig platinum B70 will not pump water through
Please get a hold of the company at the number in the manual, they will send you a new one if they cannot fix it. Magic words, I got it as a gift three months ago, it worked fine until now. Worked on mine. Sending out a new one today. This company works with you until you are happy. and I am getting 4 boxes of coffee! Free!
SOURCE: I received a Special Edition Keurig for Christmas.
I had a similar problem, I solved it by removing the K-Cup holder assembly, and pulling the small bottom piece off (it just pops off easily). From there you can access the "Exit Needle", which is where the coffed comes out and which is prone to getting clogged with grounds. Once you pull that bottom piece off you can run a paper clip or something up through the bottom of the needle and dislodge any clogs. This procedure was listed on page 13 of my manual and worked great!
SOURCE: my keurig started to take a long time to brew
Here is a tip that I wrote
that will give you some things to try that will help you get your
Keurig coffee brewer working again.
Keurig
Coffee Brewer not making a full cup of Coffee
heatman101
';';][0-
SOURCE: the keurig platinum brewer spill water from the
well I had this problem: it said NOT READY and would not draw water or heat it. I tried all the typical fixes for this problem. descaling with vinegar, taking out the waer basin and replacing it until it resealed itself, clearing the valves, turning on/off, unplugging, pressing menu rapidly after turing on, etc, etc, etc. I decided against taking it apart as I heard that it's a big pain in the bum. So I JUST BEAT THE LIVING **** OUT OF IT WITH MY FIST until volia it WORKED! ofcourse it died again a few days later. I've had it for two years and the warranty was up. costumer service was no help. So, the next day I went out and bought a new one of the same model, I switched this with the broken one and brought it back to the store saying it did not work. Let them return it to keurig and deal with those SOB's. hahaha hows that for a fix!
