SOURCE: Dead Kenwood KDC-128 CD Player Is there a "reset"
KENWOOD MADE TWO DIFFERENT EDITION FOR THIS AND SOME OTHER MODELS. YOUR WILL NEED TO CHECK THE SERIAL NUMBER AND YOU CAN CHECK WITH PACPARTS AT pacparts.com THEY WILL GET THE RIGHT ONE FOR YOU
SOURCE: display
try this
KENWOOD SECURITY CODE CLEAR procedure
Your radio will require one of the following procedures.
Type 1
During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds (so that “…” disappears).
Then using your remote enter your code.
Type 2
Press the "Auto" button and "Track up" on face of radio at the same time. The four dash lines ( . . . . ) should "disappear".
Type 3
Model# DPX-4020 and DPX-4030
Press and hold the 1 then the 6 preset key (preset keys are the buttons on face of radio for storing you "favorite" radio stations). "C" should display.
Then using your remote, enter your code.
Enter your number from the remote control unit. Your code number is 5227 (KCAR)
* Press numeric key “5” ( 2 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 3 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 1 time ) and press the Track UP/Next Track key
* Press numeric key “7” ( 2 times ) and press the Track UP/Next Track key
The security is canceled and the set enters the TUNER mode!
SOURCE: Kenwood KDC-119 car stereo problem
There is a small hole at the bottom of the stereo face that will reset the system. I pushed a pen tip into the hole and it turned the stereo off. When I removed the pen, the system turned on and the CD ejected. Problem solved.
SOURCE: kenwood kdc-mp232 not turning on
check your connections. i believe only the standby wire is connected.. or the built in amplifier detects a short on the speaker wires.
SOURCE: Help! My CD is stuck and receiver will not power up!
It sounds like the head unit is going bad. If the CD is not that important to you dont worry about it. Also you may want to check the fuses behind the head unit. Also make sure the 12 V+ Memory backup, ground, and Ignition Wires are hooked up correctly. Well, the ignition probably is, but you never know.
I hope this is helpful!
