Problem with Xerox DocuColor 12 Color Copier My xerox 2045 will not feed any weight of material out of tray three. The front edge stops between the first and second set of drive rollers. I have thoroughly cleaned the rollers and they look in perfect condition. All springs look ok and in place. This is a question for a Xerox Docucolor Engineer only
SOURCE: Xerox Docucolor 12 color copier language problem
Hi, there is no way to change language on Touch screen without calling Service. Best regards.
SOURCE: Xerox DocuColor 12 Printer
You can order them from this site..
https://www.partsdrop.com/store/
SOURCE: XEROX Docucolor 12 Color Developer PN needed HELP
DEVELOPERS:black 5R616 ; yellow 5R 619 ;magenta 5R 618;cyan 5R617
TONER : magenta 6R1051 ; cyan 6R1050 ;yellow 6R1052
SOURCE: Xerox DocuColor 3535 Copier Problem
116-325 RAP An error occurred in ESS fan rotation:---------Try reset procedure:--
to correct your issue:
Simultaneously press and hold the 1, the Stop, and the Power Save buttons on the Control Panel.
If the problem persists try:
Hold the 6, the Stop, and the Power Save buttons.If still it comes again,---------
Hold the 4, the Stop, and the Power Save buttons .If still it comes again ,-------
Hold the 3, the Stop, and the Power Save buttons .If still it comes again then there is internal problem with cooling fan .The ESS fan module has to be replaced.The part number for ESS fan module is
127K32920.To order this part you can order it from online website.click this link directly to order the parts:---
http://www.iteminc.com/parts_docucolor_1632_2240.htm
this will help.Thanks.Helpmech.
