SOURCE: HP psc 1210 will not print
Please check the printer status at control panel printer properties if it is offline or ready. Restart your computer if necessary, you will notice all pending jobs will be printed as long as there is no problem with the connections of cables and drivers. Note: Do not cancel printing jobs in the middle of sending data mode to printer or queing instead you have to remove all papers on tray and wait for the error "paper out or empty" then there click Cancel. Hopes this helps.
Best regards,
Rosener Guyano
SOURCE: hp psc 1350 -check cartridge
Power off switch for a 5 minute .
It doesn't work try to reinstall the printer driver
Or check whether the printer cartridge is fit well in the printer
SOURCE: My hp 1320 prints only one copy SPAM I AM AT 1*800*532*4187
Windows may have eaten its baby again- that is, the driver for that printer.
Open the Control Panel, then Printers and Faxes, delete any listing for that model of printer, make sure the printer is on and connected, then reboot your system.
This will force Win to 'find' the printer and install an uncorrupted driver for it.
(=Plug and Pray)
SOURCE: HP C6180 responds to print but puts out blank pages
Here is what u need Click here and follow the steps....
Thanks
Thiru
SOURCE: hp LaserJet 1320 will not print multiple copies
This problem is caused by Mopier Mode being enabled by default. The idea of Mopier Mode is to minimise computer and network traffic by sending only 1 copy to a printer equiped with suitable internal memory. That stored copy is then used to produce the multiple copies. Most HP Laserjets do not have suitable internal memory and so only the one copy sent by the computer gets printed. To disable Mopier Mode:
Click Start
Click Devices and Printers
Right click your Laserjet Printer
Select Printer Properties
Click the Device Settings Tab
Scroll down to the bottom
If necessary, expand Installable Options
Click on Mopier Mode
Select Disable in the selection box that appears
Click Apply
You will now get multiple copies.
