Electrolux 504199 Dishwasher Logo
A
Anonymous Posted on Apr 12, 2014
What does A1mean in dishwasher - Electrolux 504199 Dishwasher
OBELIX ER
Level 1:
  • Contributor 1 Answer
  • Posted on Jul 03, 2018
OBELIX ER
Contributor
Level 1:
Answers
Questions
0
Helped
228
Points
If the brand is Electrolux then A1 means "no water" or not enough pressure, to check... unscrew the water hose, if now your wet, the water is fine ??.
What was the decible rating for 66.13929k010
All this stuff can be found on Google, but only if you include FULL
'make model (what it is)'.
https://www.google.com/search?q=66.13929k010+dishwasher
Or this may be your answer
Quietest Dishwashers of 2023
Consumer Reports https://www.consumerreports.org > ... > Dishwashers
Jul 28, 2023 - Consumer Reports highlights the quietest dishwashers in its tests that are excellent at cleaning. These clean machines are so stealthy, ...
Best Dishwasher Buying Guide
Dec 21, 2022 - The Consumer Reports dishwashers buying guide covers the types, features, and other must-know topics about dishwashers.
‎Quietest Dishwashers of 2023 · ‎Best Dishwashers for $1,000...
Best Dishwashers of 2023
Apr 11, 2023 - The best dishwashers, according to Consumer Reports, include models from Bosch, Ikea, Thermador, and others.
Sep 13, 2023 • Dishwashers
Kenmore dishwasher won't run
Common solutions for: Kenmore Dishwasher will not start. The door switch prevents the dishwasher from running and working while the door is open. If the door switch is defective, the switch will stop the dishwasher from running even when the door is closed. If the thermal fuse has blown , it will prevent the dishwasher from starting.
Make sure your dishwasher is fully and also securely plugged in and that the circuit breaker switches haven't been tripped. .It also houses the door latch switch that provides the power to the dishwasher controls. If the dishwasher door isn't closed properly, the dishwasher won't receive power to finish a wash cycle You could call a repair person that fixes dishwashers to have a look at it and see what the problem is with the dishwasher
2answers
Belling dishwasher won't empty. I have cleaned the water filter and the machine worked fine this evening it won't empty?
Search Results
    Belling won t drain Dishwashers Questions & Answers - Fixya
    www.fixya.com > Forum > Tags > won t drain > Dishwashers
    Belling dishwashers won t drain related questions and answers. Ask your Belling questions. Get free help from dishwasher experts.
    How to fix a dishwasher that won't drain - Dishwashers ...
    www.which.co.uk/.../dishwashers/.../how-to-fix-a-dishwasher-tha...
    Which?A dishwasher that doesn't drain can cause concern in your kitchen, but you may not ... Check out our video to see how to repair a dishwasher that won't drain.
    i have belling dishwaher which is not emptying e1 showing as
    www.justanswer.co.uk > Appliance
    OK, so it fills and starts the cycle and then won't drain and this error will flash ... is ... the washing machine which is at the side of the dishwasher has been giving ...
    How to Fix a Dishwasher That Will Not Drain - YouTube
    ? 2:13
    https://www.youtube.com/watch?v=nr6tIO5iNSc
My dishwasher does not power up?
How to Fix a Dishwasher That Won't Start ' Dishwasher Repair
www.partselect.com/Repair/Dishwasher/Will-Not-Start/
When your dishwasher won't start it can be frustrating. ... The selector switch on adishwasher is used to select different options for the individual cycles, such as ...
Dishwasher Will Not Turn On - How To Fix ...
removeandreplace.com/2014/.../dishwasher-will-not-turn-on-how-to-fix/
Oct 6, 2014 - If your dishwasher won't turn on or start, here are a few things to check ... My Frigidaire dishwasher Model # FGID2474QFOA is only a year old ...
Dishwasher has no power - YouTube
? 4:38
https://www.youtube.com/watch?v=pp5P3Cvy9qA
Mar 26, 2010 - Uploaded by ApplianceHelpOnline
If your dishwasher has no power watch this video. For more free videos,parts,service manuals, free expert ...
What to Do When the Dishwasher Won't Start -
2answers
I have a ge profile dishwasher that does not drain well and dosent do the best job cleaning .could it be the drain
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems -
Water will not drain out
Dishwasher Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
6helpful
Dishwasher will not run. I have checked the circuit breaker and it seems fine. does the dishwasher have a reset button?
Hello there:
My dishwasher will not work at all. Investigate these four areas if your dishwasher is not working at all:
Power Supply
Your dishwasher may not be receiving any power. It is somewhat difficult to check for power at the plug outlet because the plug for a dishwasher is usually behind the unit. You should make sure all the circuit breakers of your circuit breaker panel are in the correct positions, or check to make sure no fuses of your house fuse panel are blown.
Door Switch
A properly functioning door switch will shut your dishwasher off when the door is opened. A defective door switch may not allow your dishwasher to operate at all. Examine the door switch and test it. If it is inoperable, it will have to be replaced.
Cycle Selector Switch
It isn't very common, but it is still possible that your dishwasher's cycle selector switch has become defective. Test the switch to determine if it is the cause of your problem. Replace it with a new one if it is.
Timer Motor
Your dishwasher timer will not function if its motor is defective. And if your timer is not functioning properly, then the dishwasher itself will not function properly. Test your dishwasher's timer motor, and if it is broken, you can replace either the entire timer assembly or just the timer motor.
5helpful
MY SON'S DISHWASHER WON't drain
Hello there:
Please try these things below my post and click on the links that are available for you ok
I hope that tthis is very helpful for you
best regards michael
Water will not drain from my dishwasher. Investigate these six areas if water will not drain from your dishwasher :
dishwasher_drain-hose.jpg Drain Hose
It is quite common for a dishwasher to not drain because either the drain hose or the air gap (if the unit has one) is clogged up. Drain hose clogs commonly occur where the hose is attached to the main household drain line, or where the hose connects with the garbage disposer. Try removing the drain hose to unclog any debris. Don't forget to reattach the hose before you start your dishwasher again.
dishwasher_pump-repair-kit.jpg Pump Assembly
The pump assembly is comprised of a pump, wash impeller, and drain impeller. The pump ejects the water from the unit, the wash impeller pushes water through the spray arm, and the drain impeller directs the water towards the drain port. Examine your dishwasher's pump assembly. Clean out any debris that may be blocking it. Replace the pump assembly if any of its parts appear to be worn or defective.
dishwasher_belt.jpg Belt
It isn't very common, but sometimes a dishwasher's pump assembly is driven by a belt. If that belt becomes worn and defective, then it cannot properly run the pump that drains your dishwasher's tub. If your dishwasher uses a drive belt, examine it now. If it shows signs of wear, replace it.
dishwasher_timer.jpg Timer
A defective timer could interfere with a dishwasher's ability to drain properly. Test your dishwasher's timer mechanism. If it is faulty, replace it. Keep in mind that you can replace either the entire timer assembly or just the timer's motor.
dishwasher_motor.jpg Motor
The motor plays a key role in a dishwasher's ability to drain water. If your dishwasher's motor is not functioning properly, it will negatively affect the draining capability of your machine. Test your dishwasher's motor for continuity. If it fails the test, replace the motor.
dishwasher_drain-solenoid.jpg Drain Valve and/or Solenoid
In some models, a valve has to open in order for the water to drain out of the dishwasher. This valve is controlled by a solenoid, but it is the timer that decides when the valve should open. If your timer is working fine, check the drain valve and its solenoid. If need be, replace them.
Want to replace the heating element
Can you tell me which one is your dishasher to better assist you.
HLD4040NSA
Hotpoint® Built-In Dishwasher
HLD4000NWW Hotpoint® Built-In Dishwasher HLD4000NBB Hotpoint® Built-In Dishwasher HDA1100NWH Hotpoint® Built-In Dishwasher HDA3540NSA Hotpoint® Built-In Dishwasher HDA3500NWW Hotpoint® Built-In Dishwasher HDA3500NCC Hotpoint® Built-In Dishwasher HDA3500NBB Hotpoint® Built-In Dishwasher
Thank you
3answers
Cleaning out dishwasher
Hi I checked the manual on line. Here's what it said.
Dishwasher has an odor
Run dishes being held in the dishwasher through a Rinse Only cycle.
• Many dishwashers have a “new” smell when first installed. This will dissipate with use.
• Dishwasher may not be draining properly. (See “Dishwasher Will Not Drain” section.)
• For a strong odor, place baking soda in both sides of the detergent cup. Select Light
Wash cycle and allow the water to circulate for about 10 minutes. Interrupt the cycle
by unlatching the door and let it stand overnight. Restart the dishwasher by latching
the door and allow it to complete the cycle. Another alternative is to use a dishwasher
cleaning product such as Jet-Dry Dishwasher Cleaner*.
Good Luck
Top Electrolux Dishwashers Experts
Mike Cairns
Mike Cairns
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
