Maytag PYE2300AY Electric Dryer Logo
Posted on Jun 18, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Belt installation for a maytag dryer model# sde305day
I just can remember how to install the belt to the motor and then to the tension pulley. can you help. thanks
Anonymous
Level 2:
  • Expert 121 Answers
  • Posted on Jun 18, 2009
Anonymous
Expert
Level 2:
Answers
121
Questions
0
Helped
37766
Points
261
Usally put dryer belt around the drum first
then around motor the tensioner pulley has to to be pulled up when you do this to get the belt around tensioner then you release the tensioner pulley to put tension on belt
Belt replacement- broken belt on a lde7600acw, older dryer. belt has been replaced but won't line up properly on idle pulley and motor? It appears maybe the tensioner is not set up rigt, maybe the belt...
Remember, the belt DOES NOT sit in the groove of the drum but about an inch from it in the direction of the front.
Also, the belt sits on the drum with the grooves facing away from the drum, not on the drum, a common mistake. If you have a new Genuine Maytag belt then there is a diagram of how the belt fits onto the tension pulley.
I'm trying to hook up the belt which came loose from the drum. While trying to loop it around the motor pulley, the motor pulley came free and I can feel a spring attached to the motor pulley and the...
the idler pulley keeps tension on the belt itself, and is a complete unit,, it slides into a grove,, and once the belt is correctly installed ,, thats what holds it in place, heres a good reply from another question that may help you with pictures
http://www.wikihow.com/Change-a-Clothes-Dryer-Belt
3helpful
2answers
Model: maytag LDE9606ACE reinstall belt
Go to repairclinic.com and click on the "Repair Help" link at the top of the page. On the following page, look for the "Dryer Belt Diagrams" link under the "Special Features" section. Refer to Diagram E for a Maytag dryer. If you have questions, please let me know. I hope this helps you.
Sep 25, 2009 • Dryers
How to install belt on Maytag dryer
The motor pulley usually has grooves and the gooves must match on that pulley. The belt goes around the drum gooves down thur the tensioner and on the motor pulley.
2answers
Suggested Maytag belt incorrect?
are you sure that you have it over the idler pulley correctly and motor pulley in the correct order???if not youll have slack in the belt as if it were too long,call store where purchased and make sure belt is correct, they may have given you wrong belt accidentally and while your at it maybe they can show you a diagram of belt placement on your machine,only 2 things i can think of can be wrong
1helpful
The Maytag Dryer MED5570TQ0
Hi lesterjabbow;
A lot of these dryers have a long fiber belt that runs from a pulley on the motor thru a tension idler pulley and goes all around the drum. I suspect this belt is either broken or has come off the drive pulley on the motor. You can remove the back of the dryer easily with a 1/4 or 5/16 nut driver and immediately see if the drive belt is good. Any Maytag dealer will have a replacement part and it is easy to install
Hope this helps Good Luck Loringh PS Please leave a ranking if appropriate Thanks
Install dryer belt
more information needed to specifcally match the model
however dryers are all similar so
generically, UNPLUG dryer
A:top mounted lint filter (kenmore maytag(New))
  • remove lint filter
  • remove screws in lint filter housing
  • with putty knife or other flat blade depress lock tabs at front corners of top body panel
  • tilt top panel up
  • remove screws 1/3 way down each side, remove door switch wires
  • remove front panel set aside
B:dryers with screws at bottom of front panel (maytag speedqueen)
  • remove screws from bottom of front panel
  • tilt front panel up
  • remove door switch wires
All
  • pull drum forward & out
  • examine drum felts, rollers, and slides for wear replace if worn
  • wrap new belt round drum at old wear marks
  • insert drum
  • wrap belt round motor pully
  • pull tensioner pulley hard to end of travel against spring
  • wrap belt round tensioner pulley
  • release tensioner
reassemble
Oct 19, 2008 • GE Dryers
How to instal new belt.
Remove the back panel, there you will find a tensioner, that will release the pulley.
Undo the belt routing and install the new one.
See here:
Maytag Dryer Belt Routing
belt routing for maytag performa ... -
Maytag gas dryer belt routing - FixYa
3helpful
2answers
Replacing maytag dryer belt
looking at the back of the motor where the belt pulley is you would grasp belt coming down from the left side of drum then come across the top of belt pulley that is on motor shaft going clockwise around that pulley then continue back to your left and over the top of belt tension pulley going counterclockwise around that pulley this is when you will have to raise pulley against spring pressure to get belt on then release belt tension pulley make sure that belt is still in belt groove on the drum hope this helps ed
Feb 28, 2008 • Dryers
Top Maytag Dryers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
