Dryers Logo
Posted on Jun 18, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Loud buzzing noise
When pushing in the start switch the dryer makes a loud buzzing sound like the motor is locked up or maybe the switch is bad..The drum will not turn as well nothing happens except the loud buzzing noise.. Thanks..
Rommel Balcita
Level 3:
  • Master 749 Answers
  • Posted on Jun 18, 2009
Rommel Balcita
Master
Level 3:
Answers
749
Questions
Helped
377085
Points
2156
Seems the the motor is ****! avoid switching it more further to prevent its motor from burning!
motor could be stuck due to rust build-up.
or something might have jammed along the motor area or along the rotating part.
Dryer starts and runs fine but makes a loud buzzing noise from the motor that sounds a lot like the end of cycle signal
FIXED Dryer won't start. Makes electrical buzzing noise - model ...
www.applianceblog.com/.../7655-Dryer-won-t-start-Makes-electrical-buz...
Feb 12, 2007 - 10 posts - ‎1 author
It makes electrical buzzing noise when you press the start button. ... One would think that if it's the fuse that it wouldn't buzz at all but ... unplugged, re-assembled back, hooked back up to hose, turned on and running hot .... The belt was fine. ... Kenmore gas dryer 70 series is making very loud buzzing noise.
Troubleshooting Your Dryer Noises ' PartSelect.com ...
? 4:32
https://www.youtube.com/watch?v=Tk1YezyYMDY
Aug 26, 2011 - Uploaded by PartSelect
In this video you'll learn why your dryer may be making a variety of ... that is not only making a grinding noise but it also makes a loud banging noise. ... it's been drying about 15-20 min. it startsa loud humming sound. ... The dryer is working just fine, but I am concerned about the noise as it sounds electrical.
DRYER BUZZING NOISE - Dryer For Sale
2answers
Kenmore electric dryer series 70 makes loud buzzing noice
Sounds like you have a motor problem draging and it can't get started I just replaced one same problem.
The timer makes a loud buzz sound and the dryer will not start
It sounds like your motor has gone bad....it will buzz really bad when it is tring to start and cannot...
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
heatman101
Asker's Testimonial " Thanks so much for your help. Now that you'v mentioned it, the buzzing does sound like it's coming from the motor. I'm,now, more comfortable in call " -
Dryer has started to make a loud sqealing when it starts and gets up to speed, the kind of sound a loose fan belt makes on a car, and now just makes a buzzing sound when the button is pushed but dosen't...
If you push the start button and you here a buzzing sound, This sounds like the motor is bad.
Somthing you can try and this might not work. but open the dryer door and turn the drum a littel bit then close the door and try to start it. If it starts running again then you have hit a bad spot on the motor.
If it just still just makes the buzzing noise then the motor is most likley bad.
My Maytag dryer buzzes when I push the start button. If you hold it in, the dryer will start but makes a noise, almost like a bad belt. After a few minutes the dryer will shut itself off and will not...
Remove the belt from the motor and push 'start'. If the motor makes loud noises, squeals, or the shaft has side play in several directions, then it probably is the motor. Replace it. If the the motor runs quietly, then check the drum by hand to see if it is making excessive noise while turning. There should be a little resistance to turning, but not real difficulty. Hope this helps.
1helpful
When pushing the start button on dryer, the motor makes loud buzzing noise and the drum doesn't turn.
I'VE HEARD THIS SONG BEFORE. WHEN PUSHING THE START BUTTON AND GETTING A AAARGH SOUND THIS INDICATES A BAD MOTOR. YOU NEED TO RULE OUT SOMETHING STUCK IN BLOWER. FILTER INSIDE DOOR, FRONT PANEL, TOP FILTER 95% MOTOR, ACCESS THROUGH BACK. HOPE THIS HELPS PLEASE CONTACT ME @ [email protected] AND PLEASE RATE MY RESPONSE.
Jun 23, 2009 • Dryers
Dryer makes buzzing noise but will not run.
that is the sign of a bad dryer motor-sorry-mike
May 08, 2009 • Dryers
1helpful
Loud buzz when starting, then shutting down after 10 min.
Yes, this sounds like the motor cutting out on thermal lockout.
Dryer makes a loud buzzing noise then quits working.
Sounds like the motor's done. That thing is probably the start-run switch. Not worth trying to fix on an old motor. I've found dryer motors to be fairly generic, you should be able to find a replacement. I use Repairclinic.com when I can't get parts locally.
Top Dryers Experts
john h
