Maytag 20.6 cu. ft. Model # M1TXEGMYW ice maker leaking into ice tray making icebergs. has been doing this for months and is getting worse with time. I cant see any dial or adjuster to decrease the fill of water to tray. can someone please tell me if this is normal and if there is a simple way to fix this it is only 7 years old and has had one other issue that we had to thaw it out and clear the discharge tube from debris in order to fix that one i hope this is an easier fix
SOURCE: Maytag Icemaker freezing up
Possibly a bad valve but more likely not enough water coming to the unit,follow the water line from the back of the unit to where it hooks to the pipes there is usually a little saddle valve there,try closing it all the way and then open it back up check the water through the door and see if the pressure doesn't improve.
You can also remove the Ice maker clear out the fill tube and sit a cup under the end of it for a day or two if you get water in the cup and Ice in the tube you probably have a solenoid valve that isn't closing completely.
SOURCE: I have a maytag upright freezer. It is on the
check to make sure door seals are touching the frame all round, could be an air leak,also make sure there is no ice build up around the inside casing. if so fully defrost unit,clean all vents/drain pipe, then turn back on and leave it for 24hrs (freezers work beast when full).....and door shut..how many times have you closed door after them????
SOURCE: My Maytag (top freezer 20 cu ft frig) the fan in
Check out these tips...they can help you figure out whats going wrong...
Refrigerator not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
Water Running in Refrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
SOURCE: Water on freezer bottom. I have a Maytag
Here is a tip that will tell you where the water is coming from and how to fix it. The drain hole has froze shut and the water from the defrost will not drain out.
heatman101
SOURCE: ice forms at the bottom
check for a bad/ loose/dirty gasket on the bottom side ofn the door. check your drainage line for clogging on the defrost system for back up
