I was told i could use windows movie maker to capture clips from audio files on my digital recorder. but i do not know how. i have a Sony ICD-600 digital voice recorder.. I need to transfer to my pc
It seams that this camcorder uses digital 8 media for storage ..and it does record digital ..so the transfer should not be a problem ..but it has no slot for any kind of external memory so the direct record to a external drive or flash is not possible ...but ..the way to upload the footage is simple and you just have to use a firewire cable ..and capture the footage on a video manager like windows movie maker.. The procedure is just like any other tape camcorder...just plug the cable ..let the computer see the camera ..and than use the video manager to import or capture the video while it is played back .. If your operation system does not have a movie maker ..use the one recommended by Sony on the support site ..or any other which has the capacity to capture from device .. The only way to capture directly to the computer's hdd is also with a video manager..but the camera needs to have the ability to stream ...To try it and see if it is able to ..just plug it with the wirefire...open the movie maker..and choose to capture from device and see if you have any image on the preview..If it does..it means it is capable to stream and capture in real time on the movie maker..than be saved as a video file on the hdd..
As there is no USB port on this IC Recorder, you can connect the Headphone OUT of the IC Recorder to the LINE IN of the Computer. Then, use any Sound Recorder Software to capture the files. You can also use the Sound Recorder Software preinstalled in the Computer.
After transferring the recordings to the Computer, you can use any CD Burning Software to burn the files to a CD.
With your Recorded DVD-R Disc "Finalized", and in the DVD player on your computer, you should be able to browse to your videos with Movie Maker.
In MovieMaker, on the left side where it lists:
Movie Tasks
1. Capture Video
Capture from Video device
Import video . . .
You want to "Import Video", by clicking that and browsing to the DVD-R to find what could be MPG files, or VOB files. They're both MP2 DVD format video and audio files.
Tip: Right Clicking in the Import Video Dialogue Box where the files are listed and selecting View / Thumbnails, will present a view of the scenes in each video.
An adapter will not fix the problem. The files cannot be transferred to a computer using a USB port. The files must be transferred analog using the recorder's headphone cord. The files are then recorded to the computer from the Sony recorder using a program such as Windows Recorder. The ICD-B500 has many great features but archiving to a computer is not one of them.
Use a cable running from the headphone jack on the recorder into your PC microphone jack. Then you can capture the audio using Windows MovieMaker software that comes with Windows XP. I have done this and it worked perfectly.
To transfer recordings from the Sony ICD-B600 to Windows first buy a Radio Shack #42-2497 cable. Connect the cable from the recorder headphone jack to the computer microphone jack. In Windows XP follow the path: start, All Programs, Accessories, Entertainment, Sound Recorder. This small window will allow you to record 60 seconds of sound to a file. Get Article #82215 from the Microsoft web site. It will tell you how to make extended recordings. I was able to record 45 minutes continuously. The recorder is turned on by moving the 'HOLD' switch down. The recorder is turned off by moving the 'HOLD' switch up and waiting 2.5 seconds. Have fun.
If you are using windows xp then it is easy, get in movie maker in xp. Play the clip in the preview monitor.
On the Play menu, click Play Storyboard or Play
Timeline, depending on the view you are working in, and then pause playback
at the frame of video you want to capture as a picture.
On the Tools menu, click Take Picture from Preview.
-or-
On the monitor, click the Take Picture button.
In the File name box, enter a name for the picture file, and then
click Save.
connect ur cam to ur pc used windows movie maker from XP..from start menu----------program file-------window movie maker-----------then capture video from device---start recording then drag your video to from timeline----
