Mitsubishi WD-52525 52" Rear Projection HDTV Logo
Posted on Apr 15, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a mitubishi ws-55313 with a monitor link DVI connection and I have tried to convert that to hdmi for a cable DVR but it doesn't work any ideas?
  • kitmark Apr 15, 2014
    Is it possible that the DVI port is analog and not compatable with a digital connection?
  • It's not a standard DVI, it was a proprietary connection that Mits used to connect with their outboard HD processor.
Goodman Custom Design and Installation
Level 2:
  • Expert 139 Answers
  • Posted on Apr 15, 2014
Expert
Level 2:
Answers
139
Questions
Helped
34135
Points
346
The monitor link is not a standard DVI connection, it was used to connect a Mitsubishi HD set top box. You can connect your cable DVR using component video cables and get HD that way, up to 1080i but not 1080p
  • kitmark Apr 17, 2014
    Is there a way I can convert an HDMI connection to this TV?
  • You can get an HDMI to Component converter but I don't think there would be any benifit over just connecting component from cable box to tv.
5 Related Answers
Anonymous
  • 3130 Answers
  • Posted on Jun 04, 2007
SOURCE: HDMI to DVI UPSCALING Problem
The Digital Visual Interface (DVI) is a video interface standard designed to maximize the visual quality of digital display devices such as flat panel LCD computer displays and digital projectors. It was developed by an industry consortium, the Digital Display Working Group (DDWG). It is designed primarily for carrying uncompressed digital video data to a display. It is partially compatible with the HDMI standard in digital mode (DVI-D). So yes it should work fine
Anonymous
  • 3 Answers
  • Posted on Jul 05, 2009
SOURCE: HDTV Reception
Yes , If  a  high definition device is connected to the tv then you can watch high deff tv.
Anonymous
  • Posted on Apr 20, 2010
SOURCE: I am having a problem trying to hook up a ps3 slim
try to go to the ps3 settings then go to video output settings , then go to hdmi and it should go black for a min. i didnt think it was working for mine then i unpluged it and there was a big diffrence but it should work
Anonymous
  • 5 Answers
  • Posted on Aug 18, 2010
SOURCE: I have a 4 year old Mitsubishi WD-57831. Lately,
I have run into this issue alot. I believe its because of a older version of HDMI 1.1. Quick solution is to hookup the cable box with component cables(yprpb) to utilize the HD picture still and then do some research to see if Mitsubishi has a firmware update on your particular model.
Anonymous
  • 14553 Answers
  • Posted on May 16, 2012
SOURCE: WHAT CABLE DO I NEED TO CONNECT HDMI TO MONITOR LINK DVI
I do not think the model listed here has either a HDMI or a DVI---if trying to connect a HD signal to the set it must be connected via the DTV input which is component but HD.
2answers
I have an NEC Multisync LCD4610-BK that I can't get sound output from. I'm trying to use it with a roku device that is plugged in via HMDI to DVI converter. How can i get sound?
DVI video cables don't carry audio. Thus you need to use an audio extractor or converter instead of just an HDMI to DVI adapter cable. Try something like this: https://www.amazon.com/J-Tech-Digital-Extractor-Converter-JTDAT5CH/dp/B00BIQER0E/ref=psdc_280341_t1_B01MQYTUAK . Then connect the HDMI to DVI cable to the HDMI out of the converter. Then the audio out to one of the audio connections on the LCD4610-BK. Note: this converter requires you to get the extra HDMI and audio cables separately. Depending on your ROKU device, you might need an HDMI (F to M) adapter to ensure that you aren't blocking other things on the front of the converter. Then set the monitor to the appropriate video and audio inputs separately.
I hope this helps.
Would Roku work on HPw1907 with sound?
Some of the options you mentioned will carry audio along with the video from your Roku to your monitor but not the VGA for sure it's just video on that cable. I think your HDMI/DVI converter might work though. Worth a try anyway???
Let us know how it goes? We can all learn something here.
Sincerely,
Frank
Using with a laptop
Connection the monitor depends on the connections you have out of your Toshiba laptop.
The monitor has both VGA and DVI.
If the Toshiba has a VGA out, all you need is a VGA cable available online, computer or electronics store.
If the Toshiba has an HDMI out, you can connect it to the DVI on the monitor with an HDMI cable and an HDMI to DVI Adapter.
You can also use USB out with either a VGA converter or a DVI converter (go with DVI for the better picture). Converters can be found online at Amazon, you may also need a standard male to male DVI cable to use with the converter.
Amazon com uxcell Black Blue VGA 15 Pin Male to Male Plug Computer Monitor...
Amazon com 5m High Speed HDMI Cable Ultra HD 4k 2k HDMI Cable HDMI to HDMI...
Amazon com Rankie Gold Plated DVI to HDMI HDTV Male to Female Adapter...
Amazon com StarTech com USB to DVI External Video Card Multi Monitor...
Help Adding a 2nd Monitor to ALL-IN-ONE
Try using a VGA to VGA cable or a dvi to dvi cable because dvi-d and hdmi tend to lack the necessary pins to be converted to an analogue signal. A hdmi to dvi cable may also work
2answers
I have a 2002 Mitsubishi Medallion TV. The only input for HD is DTV (no DVI or HDMI inputs). Is there a converter box from HDMI to DTV that will allow for 1080i resolution?
From looking at the back panel of the TV, the DTV input can be configured as a component video. The M-Link/DVI-HD port is also a DVI with HDCP port and maximum signal handled is 1080i. The M-Link should work with an HDMI to DVI cable or adapter. For this to work, the source must not be a computer or another device using the default computer video output (computers give RGB output). The DTV port would need an HDMI to Component video converter. See this page for some examples: http://www.hdtvsupply.com/hdtocoad.html . The first one in the list (for Netflix and Boxee among others) will give 1080i out if the source is set correctly.
Most DVI-HDMI cables are single link. I've seen some examples where DVI-I (single link) and DVI-D (dual link) cables are not interchangeable. If you have video problems, check your cable. An HDMI to DVI adapters will let you run an HDMI cable up to the TV and then converter at the TV as a separate connection.
I hope this helps.
2answers
Inputing HDMI signal to a WS-55313 55 via an HDMI-DVI cable
HDMI standard is a bear, especially "Older" versions. It should be possible to input HDMI to a DVI, either DVI-I or DVI-D, input, there are however DVI analogue too, in fact we have, 3 type of them, they are, DVI-I, DVI-A & DVI-D.... Also some HDMI do not send the Audio over it, as it should, so all in all it can be a pickle. So you MUST get a converter that works with your sort of DVI. You would have to select that DVI, input, which may be under Auxillary, or External or the like, try scrolling through your AV inputs, see if you "Find" it. if so, the set will "Read" the signal and display it automatically. The Audio, however will have to be done via the AV sockets, the Red & White stereo IN, from the DVD etc. If you have any other inputs such as Component Video, Green, Red, Blue, then this is the best way... The Audio, again must be routed to the AV, the Red & White Jacks. So ensure you have those outputs on your new DVD.
I have included a couple of links below about DVI & HDMI for your convenience. http://www.datapro.net/techinfo/dvi_info.html http://www.hdmi.org/learningcenter/faq.aspx
HDTV Reception
Dvi connection to ps3
try to hold the power button for like 6 seconds until u hear a beep...
it will reset the display and adjust it to ur monitor...
hope this helps
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
