SOURCE: Motorola Q
take the phone back into verizon and have it replaced, seeing that the phone is still under it's warranty.
You could also take it back to verizon and have them reflash the Motorola Q but seeing that it is under warranty, would not just have them give you a new one.
SOURCE: Motorola V3t wont turn back on!!!PLEASE HELP!!!
have the firmware reflash that should correct the issues.
SOURCE: My phone says No service
THE EASIEST SOLUTION IS TO GET OUT YOUR MANUAL THAT CAME WITH YOUR TRAC-FONE, AND CALL THE NUMBER THAT REFERS TO SERVICE. THEY WILL HELP YOU DETERMINE WEATHER IT'S THE PHONE OR THE SERVICE THAT IS THE PROBLEM. ANOTHER ALTERNATIVE IS TO GO TO, "TRAC-FONE.COM", AND GO TO THE SERVICE/HELP AREA..................... GOOD LUCK, JLR4
SOURCE: I need a user manual for my Motorola CE0168
Please follow this link for your manual. It gives you two options, but both are sufficient (Rogers/Fido).
http://www.motorola.com/consumer/v/index.jsp?vgnextoid=4507f7c0c1a0b010VgnVCM1000008206b00aRCRD&ps=y&pg=PG_TYP_00002&show=globalSupport&productID=bf9d5a7be49c9010VgnVCM1000008206b00aRCRD
Let me know if this does not work out for you and we will find another solution.
SOURCE: Motorola Z3 Rizr won't turn on
when you plug in the charger cable to your phone, make sure that you allow it to charge at least 2 hours, if your phone shuts off immediately after this amount of time, you likely need a new battery, they will wear out after a certain number of recharge cycles.. contact your motorola distributer or motorola website to purchase a replacement. Note do not accept "Non-Motorola Batteries or chargers as these are not guaranteed to provide the proper current necessary to safely recharge your battery, if you notice the battery getting Hot, then disconnect the charger immediately and let it cool, before removing and disposing. Remember it is normal for the battery to be warm to touch while charging or the phone itself is in use. but if it gets hot to the touch this is not normal, and the battery needs replaced..
