Question about Big Button TV Universal Remote
I have colossal remote need code for dynex tv
How do I find the remote code for my dynex TV?
Remote Control Codes For Dynex TVs ' Codes For Universal Remotes
codesforuniversalremotes.com/remote-control-codes-for-dynex-tvs/
  1. Cached
  2. Similar
5 digit remote codes for Dynex TV = 10463 11463, 11780, 11785 ... with a universal remote and work with Comcast, Dish Network, Direct TV, RCA, etc... Do you ...
RCA : Remote Code Finder : RCRN03BR : TV
www.rcaaudiovideo.com > Remote Code Finder
  1. Cached
  2. Similar
Durabrand, 10463, 10178, 10171, 11034. Dynex, 11463, 11785, 11810, 12049, 12184. ESA, 10171, 11944, 11963. Electroband, 10000. Electrograph, 11755.
Dynex TV Remote Control Codes
https://www.dynexproducts.com/remote-control-code
  1. Cached
Here is a listing of the most common Dynex TV codes for universal remote ... PHDVD5: 115; Phillips PMDVR8: 115; RCA RCU807: 135; Rogers DCT3250: 0463 ...
Universal RCA remote code needed for DYNEX tv [Solved] - Fixya
www.fixya.com/support/t8402745-universal_rca_remote_code_needed
  1. Cached
  2. Similar
Feb 22, 2011 - Hello Just buy one RCR 412BN, RCR 412SN or RCR 412SIN Universal remote control for your dynex tv. Codes are 11463, 11810, 12184. code for my dynex Google Search
Dec 22, 2016 | Dynex Televison & Video
Code for Dynex TV
Codes for Dynex TV with RCA remote control are:
Jun 25, 2012 | RCA Universal Remote Control
Living Solutions Colossal A17GO510 item #606426. how do I program for Sylvania TV?
Dunno about a Colossal, but if it is anything like a Jumbo (marketed under various names), you can try: 004, 006, 008, 019, 062, 068, 069, 075, 076, 077, 088, 116, 161, 183, or 196
OR
Turn on your TV
Press and hold CODE SEARCH button until red indicator stays on, then release
Press and release TV button
Point your Colossal remote at your Sylvania TV and press ON/OFF button repeatedly (up to 300 times!) until the TV changes channel. The red indicator blinks off after each button press
Press and release the ENTER button to install the code
May 07, 2012 | Televison & Video
I need Dynex tv codes for universal remote programming
Hello
Jensen remote has no setup code with Dynex tV. Avex-6 universal remote has setup code for Dynex TV. The code is 399
Mar 22, 2012 | Jensen JR300 Remote Control
I allready did. need number codes for my hitachi useing living so
Try the following codes:
From the Living Solutions 'Colossal' remote/Brookstone Jumbo Universal Remote (identical codes):
Hitachi TV...041, 042, 058, 059, 068, 073, 075, 078, 101, 117, 126, 127, 131, 134, 140, 145
I would think that the 'Colossal' would have the same codes as the 'Giant' version since they are from the same company. If they don't work for some reason, try the Innovage Jumbo Universal Remote codes in their manual (see below).
References (PDF Manuals):
http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=other&db=devices&br=livingsolutions
http://www.brookstone.com/jumbo-universal-remote.html
http://www.remotecodelist.com/remotes/#comp_14
P.S. I'm new to this site, but why was it asking me to recommend a remote??? I just inserted the only remote I could from the drop-down list that was relevant to this question.
Aug 11, 2009 | Televison & Video
Dynex tv code
THE CODE FOR DYNEX TV'S USING A DIRECT TV REMOTE IS 10463. THEY ARE AFFILIATED WITH SANSUI. THEY USE THE SAME CODES.
Feb 27, 2008 | Televison & Video
Remote control code
hi
you can download your manual here for the colossal universal remote.
since ilo tvs dont seem to have a specific code, you can either try the generic codes that are found here in the pdf manual.
hope this helps
http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=other&db=devices&br=livingsolutions&dv=universalremote&md=colossal3in1606426&kw=&st=&ar=&dt=&so=&pg=1&file=others/living_solutions/colossal-manual.zip
Jan 22, 2008 | Spectroniq PLTV-42HW68 42 in. LCD TV
Universal Remote Code for Dynex 20" TV/DVD
I just bought a 32" dynex lcd and saw that i couldn't program my two $5 ge remotes to work it. From reading in this forum and others I'm not the only one with the problem, I thought I was stuck with only the dynex remote. But the dynex website tells you how to get universal remotes to work,
It tells you to try the codes for Orion, Emerson, Memorex, Sansui, Sylvania, Zenith. The second orion code worked for me. both my ge remotes look and work the same but one uses a four digit code and the other uses a three digit code. I used 0135 on one and 135 on the other. There is a good chance that if you try the codes for the brands dynex lists you will find one that works. The 0135 or 135 might work for most dynex tv's.
If you have a ge remote and haven't programmed it for volume punch through you might try it. It allows the tv volume to be controlled using the ge remote even when it's set to something other than tv.
Nov 04, 2007 | Televison & Video
Big Button TV Universal Remote Logo
51 people viewed this question
Top Big Button Televison & Video Experts
ray gallant
Are you a Big Button Televison and Video Expert? Answer questions, earn points and help others
