WE NEED THE CODE NUMBER TO REMOVE IT FROM THIS C6400 ERROR
Reset C6400 ERROR
turn the power switch off and open the front cover.
Then, turn the power switch on and press the system menu/counter key to enter the maintenance mode.
Select Service setting using
the up/down cursor keys.
While pressing the start key and the # key,
press the enter key..........Maintenance mode is entered.
Select Maintenance mode using
Press the enter key.
Enter the maintenance item
number U163 using the up/down keys.
Select Execute using the up/down cursor keys.
Press the enter key. The fusing problem data is initialized.
SOURCE: KYOCERA KM-1820 COPIER
follw these steps, it should work
turn off copier.
open top toner cover.
turn copier back on.
when you see message "close top cover" press "system menu" button.
scroll up to "service setting" then press the # button, green "start" button and the "enter" button all at the same time.
then scroll down to "maint mode"
press "enter"
then enter 163
press" enter "
turn off copier then turn back on
close toner cover
you should be back in business
