Is it pssible to tnsfer contacts and texts to pc from Motorola w375? Tried a sim card reader- not woking
SOURCE: predictive text on a motorola w375
Go to Messages -->Create-->SMS/EMS-->the message multiline appears . Now press the round button in the centre of directional keys, this will take you to message editor. Now go to Entry set up . In the Primary setup select TAP english and in the secondary set up select TAP English.
SOURCE: Motorola W375 - code to activate the phone
kindly read the manuals properly. Mostly Vergin customer care should help you out with the code. If not let me know
SOURCE: sim card removal w375 motorola
If you remove the back covering of the phone and then the battery, part of the sim card will be visible. It's a rectangular card about the size of a finger nail. Usually, you can push it from one side(sometimes on the outer edge of the phone) so that it slides out of the other side but some times it's held by a spring mechanism that needs to be pulled to one side so that the card can be lifted out
SOURCE: transfer contacts from a sim card onto cell phone
Go to contact list and select the contact.press option button then press copy option then press copy to phone.
SOURCE: have motorola razr V3, how do I transfer text messages to sim rea
Hi
Thanks for using FixYa. If you have Motorola phone tools installed in your system, then you can directly copy the messages from the phone to your Computer. And, if you are unable to see the messages through the SIM card reader then the messages would be in the phone and not SIM.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
