The Closed Caption (CC) option (words displayed on television screen) came on my television on all channels and I can't turn it off. I was able to turn off CC through the settings menu but the analog CC is on and there is no option to turn off. The options displayed are: CC1, CC2, CC3... then Text 1, Text 2 etc. There is no off option.
SOURCE: closed caption wont got off on sharp flat screen
If you didn't already check your TVs MENU for it's CC options and turn them off, Check there first possibly in the Audio Section. Second is check your Cable or DTV Box MENU to make sure that is turned off. With Cable you press the SETTINGS Button and on DTV you press MENU I believe.
SOURCE: What is the difference between CC1, CC2, CC3, etc
For different languages I think cc1 is English. The rest have never worked for other languages for me.
SOURCE: closed caption problem on Toshiba 40XV645U 40 in. HDTV LCD TV
That is odd to say the least---rarely any problem in that area---are you using a cable or sat box or have a receiver in line?
The set may have a hard reset (not the one in the menu) that would resolve this--a phone call to Toshiba would answer this?
I would if a box or receiver in line look there for a CC setting and also unplug those for a while and plug back to let them reboot.
If you call Toshiba and do not like the answer ask to speak not to a service rep but a technician.
CC (Closed Caption)
To select the options in the CC sub-menu, press the MENU button or the #
button. A new menu will be displayed showing the following CC settings:
CC
The CC feature is available when watching regular analog (NTSC) TV.
Select from CC1, CC2, CC3 or CC4. Closed Caption for regular TV is
usually CC1 or CC2.
Digital CC Style
The Digital CC Style feature is available when watching digital TV.
Select either As Broadcaster or Custom. If Custom is selected then
you can customize the way Closed Caption is displayed.
1.Press the CC button on the remote to display the current Closed Caption setting.
2.Press the CC button repeatedly to choose from the four Closed Caption options (CC
Off, CC1, CC2, CC Mute). select CC off.
3.When finished, press the STATUS /EXIT button to remove the menu from the TV
