Hello I have a Kenmore Model 1102970093 serial VLP4102906 Compact Washing Machine I was doing a large load perhaps too much and the cyles were going ok, except when it went to spin and drain. I heard a clicking about 1 second intervals. The drum still had the water and the clothes in it. I removed the wet clothing and switched it to spin and drain only and it was able to spin and drain all the water. Do I need a new clutch or transmission? thanks mike canada
SOURCE: Kenmore model 11044832200 ( ourchased
have you cked the belt on back and is still on the drive . or ot may be broken. washer will fill and drain and prosser thinks tis going . . so i would ck the drive . mm hopw this helps m ,m feed back pls .. ,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
