SOURCE: how to tighten cable on pop up camper
the adjustment can be done by your dealer, contact them see how much it costs.
SOURCE: 1995 Coleman Utah pop-up won's stay up
I had the same problem on my 1997 Coleman Fleetwood Bayside. I took out the spring pin from the crank shaft using a finishing nail and a hammer. I then put a 9/16th" socket inside to hold the nut in place while I used a pipe wrench on the outside of the crank shaft to turn it about 1/4-turn clockwise. Voila! Now it works.
SOURCE: best method to repair cracks in the white
"JB Weld" Might Work.. Then Paint Over to match Camper
SOURCE: I need a repair/owner's manual for 1999 Coleman
Tried googling Coleman? They might be able to help.
SOURCE: Trying to locate a manual for a 1985 Coleman
Have you tried e-bay or craigs list? Also try googling it, or look under camper manuels. It may take a little research but something should be out there.
