Question about Samsung GALAXY TAB 2 7.0 8GB BLACK P3100, Tablet, GSM Voice
My samsung galaxy tablet is not coming on and i am still charging it
Well i was playing on my tablet and i went away for a few minutes. when i came back it was off and i couldn't get it back on. i tried blowing some air into it and took the SD card out but nothing works. i have been trying for 2 - 3 days now and nothing is happening. i am starting to lose hope. this has happened before but it came back in two instead of 3 days. but when it came on it just keep showing the logo but eventually it came back
    Habit-Forming:
    New Friend:
  • 30 Answers
I'd suggest you disconnect the battery, wait for ~3 minutes, connect the battery again and try booting the tablet once more.
The problem could either be a hardware issue or a faulty OS, the latter meaning you should factory reset and reinstall the tablet.
Samsung Galaxy Tab 2 7 0 Battery Replacement
Posted on Jul 01, 2017
6ya staff
SOURCE:
Anonymous
  • 3 Answers
SOURCE: My cell phone battery died. When I went to
This is not a regular thing. Maybe if you buy a new battery that might work.
Posted on May 09, 2009
meteshadow
  • 489 Answers
SOURCE: Samsung Alias will not charge.
try with another battery. if it charge you have battery problem. if it doesnt you have motherboard problem with phone
Posted on May 30, 2009
phil
  • 567 Answers
SOURCE: Samsung Jet Cell Phone is "dead"
under warranty will not count on liquid damage if you take the battery out you will see a red dot that tells you water damage i have dried out some mobiles take out battery and sim leave on warm radiator couple of days then try again if still the same then it spares cost way too much to put right needs mother board ,and connectors hope this helps
Posted on May 11, 2010
caroldon
  • 17130 Answers
SOURCE: I have in Safe mode my Samsung Galaxy Indulge And
It seems that the software is corrupt and you will need help from the service center as the software needs to be installed once again. This could have been due to a corrupt file caused by a virus. So for a final try you can remove the memory card and use your card reader on the PC to have a scan to check for malwares. If so delete and keep battery removed for few minutes before you can try once again before assistance from the service center is needed.
Posted on Nov 05, 2011
SOURCE: samsung galaxy stellar keeps freezing
I fixed mine!!! Okay. This is what you do. Make sure your phone is off and to turn it back on press Volume up and the Power on button at the same time until it says something like rebooting system at the very left top in blue. A menu will come up. Using the volume up and down, select the reboot option. It will wipe everything out, but as long as you are set up with google, you wont lose your contacts. There will be a confirmation question with a bunch of no's and a yes. Select yes using the power button. In yellow writing at the very bottom it should say that your phone has been rebooted. It will then turn on by it's self and you will have to re- set up your phone just like you had to the day you first got it. Sorry I don't remember everything word for word, but I just got off the phone with a representative and that's what he told me to do. It worked!! If it happens again though, contact your provider and tell them. They will replace your phone if it's still under warranty :)
Posted on Nov 18, 2012
Esquire Wireless shuts off during play
Think I might just have discovered the issue here. I had the same problem but didn't realize that the volume was maxed on the unit (as I was controlling it through the phone). As soon I brought the volume down on the unit the problem went away.
Apr 13, 2014 | Harman Kardon Audio Players & Recorders
My tesoar tablet showed charging for 3 seconds then that was it now it wont turn on it wont do anything
I have a hacker inside my Samsung galaxy 8 notebook, he controls my ph and I pad, how do I break the tracking link.
Mar 21, 2014 | Samsung Galaxy Tab GT-P7510MAVXAB Tablet
Wont come on
Happened to me. My solution was to fully charge, then hold down power button for like one minute or more continuously. It causes some kind of restart. Last resource, Press Vol Down and hold, then depress power button and hold. This causes it to go back to reset mode. Good Luck.
Mar 04, 2014 | Samsung Galaxy Tab 2 Nd Generation 7 8gb...
Cant get my samsung tablet to turn on
Your tablet's battery is probably dead. This may be because you have a bad battery, a bad charger, or a bad charging cable. Try using a different cable first and let it charge for a few hours - even if it doesn't look like it is charging.
If the new cable doesn't do it, try using a different charger. Samsung devices are picky about what charger you use, so try to use one made for your tablet. If you don't have another charger, plug it into a PC's USB port with the PC turned on. Leave them on and plugged in over night. That should trickle charge your tablet.
If neither of those work, try holding down the power and the Volume Up buttons. Keep them both pressed until the Samsung logo/boot screen comes up - should only be a couple seconds. Once the logo comes up release the power button but keep holding the Volume Up button. That will boot you into Recovery Mode. If that comes up, it means you've got power and your tablet isn't broken, but there is something wrong with the Android OS that is keeping your tablet from powering up normally. Use the Volume Up and Down buttons to move the selection highlight to the Factory Reset option. This will wipe all the info off your tablet and put it back into a "brand new just out of the box" state. You'll lose your information on the tablet, but this should fix the boot problem. Press the power button to chose the Factory Reset option. It will take a few minutes. Once it says that it is done, select the Reboot or Restart option. It should reboot. This boot will take longer than normal, since its wiping things out. But not more than a few minutes.
Jan 02, 2014 | Samsung Galaxy Tab Tablet PC
My samsung galaxy ce 0168 screen is not working anymore after 2 minutes turned on
Check that the charging port pins are not bent or damaged or corroded use a small needle to clean each individual groove. Replace the charger, suggest Staples or Walmart for the source.
Dec 05, 2013 | Samsung Galaxy Tab Tablet PC
When I try to charge my samsung galaxy tablet a yellow triangle pops up on the battery sign
I had this same thing. The Batter image had a red line on the right side and the yellow triangle had an explanation point in the middle.
I searched the net and found a few solutions.
1. Hold the power button down for 30 seconds.
2. Hold the power button down and the volume down button at the same time for 30 seconds.
3. Just let it charge and over night and it should go back to normal.
I did all 3, in the order I wrote them. While in step 3, after about 5 minutes I pressed the power button and it showed that it was charging normal.
Hope this helps.
Dec 04, 2012 | Samsung Galaxy Tab Tablet PC
My galaxy tablet just went dark. No screen or power. It was more than 50% charged last I looked an hour before. It has been plugged in for 20 minutes now and it won't turn on. What happened??
it depends.. check the battery pack maybe this cause a over charge and check first if your galaxy tablet is still part of the warranty this will help you a lot.
Dec 09, 2011 | Samsung Galaxy Tab Tablet PC
Samsung GALAXY TAB 2 7.0 8GB BLACK P3100, Tablet, GSM Voice Logo
62 people viewed this question
Top Samsung Cell Phones Experts
Felizardo Erilla
Felizardo Erilla
Bill Long
John Tripp
John Tripp
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
