Question about Toshiba 32AV502R LCD TV
Reset toshiba flat tv
Blinking light
4 Suggested Answers
6ya staff
SOURCE:
rulds2008
Grand Canyon Tech
  • 3866 Answers
SOURCE: TV will not turn on
The flyback transformer will need to be checked as these are the culprits when you get the flashing light in the frount. also whatwould need to be checked is the 240V Capacitor inside to make sure that its in order as well.
thanks I hope it was Very helpful to you today
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Dec 02, 2009
Testimonial: "advice gave me a good starting spot"
Anonymous
Check for burned out resistors, capacitors and diodes in the HOT ZONE on the chassis. It appears that your power supply is not generating enough power for your TV to start up. There is a high probability that there is some capacitor that gone bad. But still check everything just to be sure.
hardrocko
Kim Yearick
  • 1476 Answers
SOURCE: Flat screen Toshiba TV cannot
See my tip at http://www.fixya.com/support/r4606286-troubleshoot_dlp_tv for help with this problem.
Thanks for using FixYa and for the great rating.
hardrocko
Posted on Sep 07, 2011
Tv not coming on has a blinking power button
Toshiba CX36F85 36" TV Blink - Questions - Fixya
www.fixya.com > ... > Toshiba > Toshiba CX36F85 36" TV
Toshiba CX36F85 36" TV, blink related issues. ... Every brand TV will have its ownblinking ... stand by light blinks 6 times, wont power on tv is only 4 years old. ...From the number of blinks occur at one time switch ON, you can get an idea ...
Toshiba CX36F85 36" TV Blinks - Questions - Fixya
Toshiba CX36F85 36" TV, blinks related issues. Get free help ... Every brand TV willhave its own blinking codes. From the ... Push power button and it ... and then ... stand by light blinks 6 times, wont power on tv is only 4 years old. Junk! it wont ...
Toshiba power light blinking not turn Standard (CRT ... - Fixya
www.fixya.com > ... > Standard (CRT) Televisions
Jan 10, 2016 | Toshiba CX36F85 36" TV
Blinking power light
How many times this standby/power light blinks at one time switch ON?Count it carefully.These blinks are fault indication, and known as blinking codes.From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV.This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/
Dec 10, 2013 | Toshiba 42HP95 Television
A Toshiba Flat Screen (52"
U tries check the power source and unplug,replug the tv back like about an hour later.For the tv to do a resetting itself back to the factory setting.No,fans in LCD or Plasma flat tvs.If this tv a LCD flat screen tv than the tv have power supply board problems,this tv doesn't have fan design into it.After it goes off the tv power LED light indication on the tv bazel frame are blinking?Yes that the tv have a power supply board can't sustance power voltages to the tv anymore.The tv power supply board that the board where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish power supply board for the replacement.Or have the tv service by a athorized LCD tvs and Plasma tvs shops.
Aug 17, 2011 | Toshiba 52HL167 52 in. LCD HDTV
The power light blinks 3 times. What does this mean?
Toshiba Flat Panel Television how-to instructions, help and tips Three times so far, just the tv not the cable. Toshiba Flat Panel .... Timer light blinking red. TV will not turn on by power button on TV or using the ...
tv.manualsonline.com/.../toshiba/.../flat_panel.../product_problem toshiba.justanswer.com
Mar 11, 2011 | Toshiba Televison & Video
Blinking red light on bottom of tv
Have Toshiba Regza 42" LCD HD TV. Turned on TV. Heart a pop. Power light on TV blinks 3 times.
Dec 20, 2010 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
TV will not turn on Yellow power ind. Light blinks three times tried to reset no luck took to repair shop diagnosed with bad SEIN module internet post suggest bypassing Sein module but I don't know where...
Toshiba Regza 37in - 37HL17
TV will not turn on Yellow power ind. Light blinks three times...
Fixed with a firmware update (hard to believe, but true). Search Google for a file named: 2007SEN069.zip (don't worry if the page you find it on doesn't mention the 37HL17 - it worked fine). Unzip the file, and copy the 3 folders and 3 files to the root of a small SD card. The SD card MUST be 2GB or less in size (I used a 1GB card), and it MUST be formatted with FAT-16 (not FAT-32). Mine was pre-formatted as FAT (FAT-16). The SD port is on the back of the TV behind a cover plate near the power cable. You do NOT need to remove the back cover of the TV, just the small cover plate (1 screw). UNPLUG the TV; remove the cover plate; insert the SD card (prepped as explained above); Plug in the TV; Watch the yellow lights blink, then turn blue, then go dark; UNPLUG the TV; remove the SD Card and replace the cover; Plug in the TV; Yellow lights will blink a few times (this is normal); when blinking stops, turn on the TV and you should be good to go. :-)
Pictures attached are from a Toshiba software upgrade bulletin I found online.
cc46e8cd-c98d-439a-bc78-207613c68534.png 76bab8a5-e5dc-4d5d-9d56-589661460254.png
Jan 13, 2010 | Toshiba Regza 37HL17 37 in. LCD TV
My toshiba 42HL167 won't turn on
Try this fix from the toshiba website. Q. I have no picture or sound, but I have a blinking power light?
Models: LCD-2007
REF:FAQLCD00090
1. Try resetting the TV by disconnecting the power for 30 seconds and then plugging it back in. If this has no
effect, try moving the TV to a different power outlet that has been tested and is known to be good.
2. If your unit continues to fail, please contact our Customer Solutions Department at 1-800-631-3811 Monday
through Friday, from 8 a.m. until 7 pm CST for a local Toshiba Authorize Service Station Hope this helps you with your problem.
Feb 27, 2009 | Toshiba 42HL167 42 in. LCD Television
WILL NOT TURN ON
you might have to reset the code on the remote or do a code search
Apr 08, 2008 | Toshiba 37HL67 37 in. LCD HDTV
Toshiba 32AV502R LCD TV Logo
44 people viewed this question
Top Toshiba Televison & Video Experts
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
