Question about Zhone (6218-I2-200) Router
How to set ip address with windows 7 - Zhone (6218-I2-200) Router
How to Find my IP Address (Windows 7/8, Windows XP)?
If you go to your windows search box and type in CMD you will be defaulted to dos and then you can type in : IPRelease command and then type in : IPRenew and your new IP address should show in dos. Hope this helps.
Oct 19, 2016 | Computers & Internet
Tip
How to set up a static IP address in Windows Vista
Static IP addresses are often used for computers that host specific services, or for computers on small, manually managed networks. To set up a static IPv4 address on a Windows Vista computer, first find an IP address that is not currently in use and is outside the DHCP assignable range (if applicable). Then follow either of the procedures below.
From the taskbar:
1. Right click on the network connection icon in the system notification tray.
2. Select Network and Sharing Center.
3. Under Tasks, select Manage network connections.
4. Right click on the network connection that you want to set up the IP address for (Local Area Connection, Wireless Network Connection, etc.)
5. Select Properties.
6. If the User Account Control window pops up, select Continue.
7. Click on Internet Protocol Version 4 (TCP/IPv4).
8. In the Properties window, click the circle next to Use the following IP address.
9. Enter the IP address that you want to assign to the computer.
10. Enter the subnet mask and default gateway. (For small or home networks, these will typically be 255.255.255.0 and 192.168.1.1, respectively.)
11. Enter the IP address of the DNS server next to Preferred DNS server.
12. If you have an alternate DNS server, enter that IP address as well.
13. Click OK to save the changes.
From the Start menu:
1. Click the Vista orb.
2. Right click on Network.
3. Follow the procedure above from step #3.
Reserving an IP address under DHCP is different from setting up a static IP address. To reserve an IP address, log into your router's configuration utility and look for a heading such as DHCP or IP Address Distribution. You will probably need either the computer's Windows name or its MAC address to reserve an IP address for it.
on Jan 30, 2011 | Computers & Internet
How to set an ip address
To set an IP address in your PC Laptops (Windows 7, xp and vista) visit the site Howtogeek.com ,here they have given detailed procedure to sen an IP address of your own. After setting an IP address you can check it in two ways.
1)Go to Start-> Run-> Cmd Press Enter.. Type ipconfig or ipconfig/all command line to know your IP address.
2)Visit the site Ip-Details.com to get your IP address.
Apr 10, 2013 | Computers & Internet
How to find my ip address on windows 7
You can find your IP address on windows 7,by following the below steps:
1.Start->Run->cmd prompt
2.In that,just type ipconfig and then click enter
For example: It will show ip address like 74.110.208.65
If you want to find your network ip address that is provided by your ISP,visit Ip-details.com .
Mar 30, 2013 | Black Box IP Address Translator With...
How come the http://192.168.123.254 address isnt working?
Find your computer's IP address : Windows 7, Vista, and XP, using the command prompt
  1. Click Start, and then select All Programs. Note: If this doesn't match what you see, refer to About navigation settings in Windows.
  2. Click Accessories, and then Command Prompt.
  3. At the command prompt, enter: ipconfig The IP address (or IPv4 address, if you are using Windows 7 or Vista) will be a series of numbers following the pattern xxx.xxx.xxx.xxx (i.e., 156.56.27.32).
Note: If you are using PPP with a modem at home, your IP address will change each time you log in.
Windows 7, without using the command prompt
  1. In the system tray, click the network connection icon and select Open Network and Sharing Center.
  2. To view the IP address of a wired connection, click Local Area Connection. To view the IP address of a wireless adapter, click Wireless Network Connection (Network Name).
  3. Click Details... . Your IP address will appear next to "IPv4 Address".
Windows Vista, without using the command prompt
  1. From the Start menu, right-click Network, and then select Properties. This opens the Network and Sharing Center.
  2. To view the IP address of a wired connection, click View Status to the right of Local Area Connection. To view the IP address of a wireless adapter, click View Status to the right of Wireless Network Connection.
  3. Click Details... . Look for the address next to "IPv4 IP Address".
Windows XP, without using the command prompt
  1. From the Start menu, right-click My Network Places, and then click Properties.
  2. To view the IP address of a wired connection, double-click Local Area Connection. To view the IP address of a wireless adapter, double-click Wireless Network Connection.
  3. Click the Support tab, and then click Details... . The window that appears will display the IP address.
Your IP address has to be in the 192.168.123.xxx range
The router must be configured to match your
Internet service. If you do not know your
Internet connection configuration, please
contact your Internet Service Provider (ISP).
By default, the router is pre-configured with
these settings:
• Automatically set IP addresses for
computers on your LAN (connected to the
router's ports 1-4). The router acts as a
server for dynamic host configuration
protocol (DHCP) and assigns IP addresses
in the range 192.168.123.100 through
192.168.123.199
• The default LAN IP address for the router is
192.168.123.254 with a subnet mask of
255.255.255.0
• The Internet service connected to the
router's WAN port uses a dynamic IP
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Dec 26, 2010 | Asante FriendlyNET FR1104-G Wireless...
I purchased an HP LaserJet Printer back at the end of 2006. I was able to use this printer under Windows 7 until I attempted to use it with a different Internet configuration that requires DHCP to be...
Hp2600n is host based. It would not work properly with DHCP. If the printers use DHCP, I would suggest assigning a manual (static) IP to the printers and see, if that makes a difference.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Nov 13, 2010 | HP Color LaserJet 2600n Printer
Forgot user name and password
All Linksys routers have a built-in web-based setup page that allows the user to customize settings and set up advanced properties.
NOTE: Before accessing the router's web-based setup page, make sure the router is powered on and the computer is wired to one of the Ethernet ports on the router (1, 2, 3 or4 ).
Accessing the Router's Web-Based Setup Page
NOTE:To access the router's web-based setup page using Mac, click here.
Step 1:
Open a web browser such as Internet Explorer.
Step 2:
Go to the Address bar and enter your router's IP address ("192.168.1.1" is the default IP of most Linksys routers) then press [Enter].
NOTE : For WRP400, the default IP address would be "192.168.15.1" and if you place the router behind a primary router with the IP address of "192.168.15.1", then the router will automatically assume a new default IP address, "192.168.16.1".
NOTE: If the IP address of the router has been changed, type the router's IP address in the Address bar instead.
The router's IP address can be changed by:
1. Running the router's setup CD.
2. Changing it on the router's web-based setup page.
If you forgot the router's IP address you can:
1. Check the router's IP address. For instructions, click here.
2. Press the Reset button at the back of the router for 30 seconds.
NOTE
: This procedure will reset your router to factory defaults. Any settings on the router will be erased. The router's IP address will be "192.168.1.1" and the password will be "admin".
Step 3:
A new window will prompt for a User name and Password. Leave the User name field blank then enter your router's password ("admin" is the default password), then click OK.
If you forgot the router's password you need to reset the router. For instructions, click here.
Windows XP
Windows 7
NOTE:
If the password of the router has been changed, type the router's new password in the Password field instead.
The router's password can be changed by:
i. Running the router's setup CD. Click here to learn how to download firmware.
ii. Changing it on the router's web-based setup page. Click here to learn how to change password on the web-based setup page.
Unable to Access the Router's Web-Based Setup Page
Reset your router for 30 seconds. Try accessing again using the default IP address "192.168.1.1". If you are encountering problems accessing the router's web-based setup page, click here.
Related Articles:
Setting-Up WPA Wireless Security on a Linksys Router
Changing the Wireless Network's Name (SSID) on a Linksys Router
Setting-Up a Router with DSL Internet Service
Downloading at Linksys by Cisco Support Site
Nov 06, 2010 | Linksys Wireless-G WRT54G Router
I have an aptiva desktop and i need an ip address in order for my internet to work
But do you have any internet connection??if yes and if its DSL than ur dsl router will automatically provide ip to ur pc???
Sep 08, 2010 | IBM Aptiva E 572 (2174572) PC Desktop
How do retrieve my IP ADRESS FOR MY COMPUTER & WIRELESS ROUTER
your ISP should be able to help you in that...check with the person with the internet company...
Jul 30, 2010 | Computers & Internet
I have a trendnet wireless router tew 432brp, a new hp windows 7 laptop, and old xp laptop and i want to share the connection with my verizon um175 aircard. this has worked for several years with the old...
The router connects computers together . You are using a windows 7 p.c and connecting it to an internet connection via a usb verizon um175 aircard.
I think you need to share the internet connection with the rest of the network and may need to feed the ethernet cable into the feed port of the router. I have not done this before but logically the windows 7 computer would have to act as a gateway to the internet.
http://www.dummies.com/computers/operating-systems/windows-7/how-to-share-an-internet-connection-in-windows-7/
https://www.ibvpn.com/billing/knowledgebase/53/Internet-Connection-Sharing-on-Windows-7.html
Note the default gateway is going to have to be the windows 7 ip address on the other computers
You may need to set the ip address on windows 7 to a static address and then change the dhcp server settings default gateway and also increase the first address to not include the windows 7 ip address or the routers ip address in the lease range for shcp.
Mar 17, 2017 | Trendware TEW-432BRP 54Mbps Wireless...
Zhone (6218-I2-200) Router Logo
27 people viewed this question
Top Zhone Computers & Internet Experts
Prashant M
Prashant M
Joe Goldman
Joe Goldman
Mike
Are you a Zhone Computer and Internet Expert? Answer questions, earn points and help others
