I install paper into the cassette and select the correct paper size but when the tray raises, the printer does not detect that it is in the up position and just keeps trying to raise the paper which causes the gears to click trying to raise the paper more even though it's already up. Help??
There is a limit switch that detects when the paper is up.Check it to see if it moves freely.
Testimonial: "The limit switched had a bent bracket preventing the roller assembly to raise up and set into the sensor..However, now that it does sense the paper, it detects a jam when the tray is empty. It does not sense paper out....What could be causing that problem??"
SOURCE: kyocera fs-3900DN
Very weird message! Pull down the by-pass tray in the front of the printer and insert a sheet of paper , then print.
SOURCE: Paper Jam
Ok, The Copystar CS-1820 is a Lemon, as an Authorized Independant dealer for Copystar. I can attest to this. This is a common problem from Copystar and their's not much that can be done. Unfornatel they should of stuck to the CS-1810 design they would of been better off/
SOURCE: paper tray full message and not printing
there is a black tab in the center where the papers come out that is the tray full sensor arm that is more then likely stuck
SOURCE: wont print on card stock, legal paper- keeps jamming
Menu> scroll to Paperhandling> MP Tray type>>(plain) try changing this to cardstock <enter>
instead of MP Tray type do the same for Cassette if you desire....
Best,
danakadan
SOURCE: Copier says there is no paper in tray when there
Check what size paper you are telling the machine to print on to as the nachine does not have the correct size paper in it will come up with this message constantly.
