My tv remote is loss and my tv is mute mode how can unmute without remote
SOURCE: AOC A27W221 27 in. LCD Television Problem
This sucks the same thing happened to the one I had. What happened is the power supply burnt out. Yes I took it apart and took off the power supply and it had black under it. Something got burned. If you replace the power supply it should work. However if you find a power supply and are will to pay about a hundred dollars for it because people are cheap it really isn't worth fixing. Why fix it when it could easily burn out again.
SOURCE: CANT GET SOUND GOING ON
Go to menu audio section. Check if there is a feature that says 'speaker off/on. If there is, check if it is turned on. Other than that ask for a repairman to check the audio section of your unit.
