I heard that the flashing codes on Panasonic plasma units represent a specific type of error.
upon plugging in unit and pressing power, the red light flashes 10 times -- do you know what that represents?
Hey there! i finally figured it out!! If you have a computer hooked up with the HDMI cable in the back of the TV and the computer is either on screen saver mood or sleep mood then it is trying to make the television go to sleep aswell. So the only way you can have a computer hooked up to the TV is if you use the front HDMI hook up. pretty weird but thats what was wrong with mine. Hopefully that was the problem :):)
I bought this tv in August of 2008. First episode occurred in October of 2009 - after manufacturer warranty had expired. It returned back to normal. Second episode occurred in March of 2010 and never got the unit to power up.
I had an electronic service center check it out. Turns out it's a defective power unit that's misfiring. The misfire triggers the overheat error code.
Panasonic retailer wanted $575 for parts and labor.
Service center executed finely and strapped on a 6 month warranty for $375.
I will be faxing a copy of the invoice and original receipt for a reimbursement.
I have the same problem...
if anyone has had a solution please let me know.
meanwhile i did find this link that might help explain what is wrong:
http://www.bruzziforum.com/vbf/showthread.php?t=79
I found a solution that might work for a few people. I had my mine (TH-42PX80U) set up with my PS3 on HDMI1, X-Box on HDMI2 and computer on HDMI3. After moving yesterday, my PS3 and computer ended up on 3 and 1 respectively. Then this morning I had the red light for the first time in two years. Apparently the video cards on some computers cause problems for the plasma unless they're plugged into HDMI port 3 like I originally had it. I made the switch, unplugged the tv for thirty seconds, and presto, problem solved.
Hiya there i have the same problem but because my tv is about 20 years old it proberley have just blown out the tube in the tv. panasonic tv TC-14JR1 that is my tv model its old i know but cant afford a new one (: Anyways mine keeps constantly flashing and wont turn on for some reason its cutting out to standby! I wonder if its the fuse in my socket???? lol Any suggestions would help thanks, or you can email me directly [email protected]
I have the same issue. Originally the tv just shut off, no blinking light whatsoever. Wouldn't come back on so I bought a new power supply board. After installing the new board, I now get 10 blinking lights. Does anyone have another solution for this?
I am having the same 10 blinking lights issue with my TV. I ran some diagnostics and I suspect the problem is the P board (power supply board... the only beige one). However, the 10 blinking lights can be indicative of 3 different board problems.
1) The P Board
2) The PA Board
3) The H Board
Or a combination of the above. If you already replaced the P board, try the following..
Disconnect the connection from the PA board to the H board. Turn your TV on. If you see 10 blinking lights, your H board is fine. If you don't, replace your H board. Next, disconnect the connection from your P board to your PA board. Turn on your TV. If you see 10 blinking lights, your PA board is fine, if not, then your PA board is also messed up.
If running both these tests still produced 10 blinking lights both times, then it could be 1 of 2 things. Either you bought a bad P board, or your PA board is messed up. The only way to differentiated is by checking voltage, which I'll assume you'd rather not do.
Good Luck!
I was struggling with same problem,I am lucky to find the cure at no cost.In my case D935 on main pcb (with tunner) was not seated properly thus not sending pulses to Y Sustain pcb
Ajeet
[email protected]
same issue. also blew one line fuse. In order to see 10 flashes, had to replace fuse. Suspect SS board.
same thing on my tv!!! started today. waiting for service under warranty
I now have the same problem. The power board was replaced by a tech and now the red light flashes 10 times. he does not know what it means excwpt that there is an error. Any help would be appreciated.
Join the club - set worked perfect for 1 1/2 yrs - out of warranty - Panasonic denies big problem. Blew both line fuses, replaced, now I get 10 flashes and no power up. Just tell me which board to buy! Discount-Merchant has the least expensive prices.
exactly the same problem. set is about 1half - 2 years old - Panasonic.
Just suddenly went off.
Light falshes ten times.
Called Panasonic who were BEYOND HOPELESS !!!!! ....rude and USELESS and then demanded $145 to 'possibly fix it...bu we dont really know what the problem is"...
I said YOU ARE KIDDING !
Ridulous that you spend that money on tv and it just decides to stop working afterless tha 2 years. ****!
panasonic plasma tv, red light flashes and sometimers will not turn on
