On Auto pics do not transfer to the SD card. Internal memory full.
SOURCE: On my Kodak M863 digital
click review press menu go to copy click photo or all that should transfer photos to sd card .
SOURCE: Trying to transfer pics on internal memory to my SD card.
Set the image storage setting of the camera to Internal.
Once it is set to internal, put the card in the camera and press review.
Copy the pictures from the internal memory to the card.
SOURCE: Kodak EasyShare C633 not reading any SD Card
check the manual for any such thing like "memory card problem" or open the page that talks about it, it may contain useful info
usually there is a preferred type recommended to use
using a memory card that was installed in other cameras may change its format or file structure, this may cause your camera not to recognize it, try formatting the card and then install it again, most cameras have a "format" option in the menu, try it out
there might be a "reset to factory defaults" option, this may reset your camera to the way it was originally it was in, could solve it
SOURCE: pix transfer from internal to card
Question :
How do I transfer pictures from the internal memory of my KODAK Digital Camera to a memory card?
Answer :
Follow these steps:
SOURCE: how to transfer pictures from internal memory to
Make sure a card is installed. In any still or video mode, press the Menu button. Press up/down to highlight Image Storage then press the OK button. Press up/down to highlight Internal Memory then press the OK button. (You'll need to set this to Auto later if you want pictures to go to a memory card instead of the internal memory.) Press the Review button, then the Menu button. Press up/down to select Copy>> then press the OK button. Press up/down to highlight what you want then press OK.
