Copier is making a gringing noise when it is turned on. There is a lot of toner leaking inside the machine and the copies have black marks on them.
SOURCE: xerox 5305 copier excess toner
sounds like faulty drum cleaning blade,which is usually contained in the replacement drum module.I would be inclined to take the drum unit back where you got it (unless you replaced it with a second-hand one) 99% certain the problem is contained in that module
SOURCE: xerox grinding noise
the bearing on the motor or the rotating path must have damaged..
replace them
SOURCE: GRINDING NOISE or PAPER JAM
If you are not a technical person best thing to do is to show it to an expert. grinding noise means some part in the machine is running with the friction. and might brake something or scratch something. Find out persons who work on photocopiers in your area either samsung or Xerox. as this model comes with both the companies and Xerox people are generly better than samsung people.
SOURCE: Canon IR3100 CN making grinding noise
hi..there...you may visit canon website at internet..chose product support/dowlnload----find your product here and finally you can get and download manual book as pdf for free....good luck..
