There are two lights for the antenna.when you are transmitting the top light will change from green to red the bottom shouldn't be on.this is the awi light. it means there is a problem with the antenna system, and you should get it checked. It could be the antenna swr ,bad coax,or the radio.Since you can't do anything with the coax or radio it has to be done with the antenna. Get a real SWR meter and check the SWR or have a tech do it. If the SWR is ok then your antenna just might be in the wrong spot ,or it may need to be grounded A tech will tell you the problem as soon as he puts his meter on it.
SOURCE: antenna light still on
The antenna warning light on the Cobra 29 LTD has a pot ( varabile resistor ) that sets the senativity of the light coming on. If you open the radio, you'le see the pot at the back of the radio. It's the last pot in the rear of the chassis Simply turn it more torward the center of the setting ( anyplace is ok as it means nothing to the preformance of the radio ). The light won't come on unless the SWR's are high. Good Luck and if I can help more, you can email me at this address or at my email address [email protected].
Ed
NC Electronic
Mills, Wyoming
SOURCE: antenna light comes on when trying to transmit
Its the antenna. it is not tuned correctly for the radio. First, stop transmitting. You can burn out the final transistor. If the antenna light is coming on, that means your SWR is too high,
first. Check to make sure that the antenna coax is securely attached and fastened tightly to both the radio and antenna.
Next inspect the coax. Make sure there is no damage to it. If there is a slice in it, it is kinked really bad, that could be the problem.
Now, if the coax looks good and is connected tightly, now its on to tuning the antenna. Your antenna is either too long or too short. Antenna's usually have a way to adjust this. Most common is where a metal whip sits in a collar. You loosen the collar, and you can move the whip up and down in it. That is how you adjust the length of your antenna. Fiberglas whips usually have an adjustment at the tip that you can adjust usually by screwing it in or out.
Now here is how to check your SWR.
Make sure you are in an open area like a parking lot as structures such as buildings and trees can cause reflection and give you a false reading. Always take an SWR reading with your doors and windows shut as not doing so can also cause a false reading.
Now that you are in an open area, turn on the radio and turn to channel 20. flip the switch located all the way to the left by the signal meter to CAL. Now turn the knob all the way to the right just before the channel selector marked SWR CAL all the way down to the left before you start. Now key the mic without talking into it and turn the SWR CAL knob up until the needle on the meter is all the way to the right to the mark for CAL. its a little upside down triangle with the letters CAL next to it. You want the needle to be on that triangle. Now while still holding the key in, flip the switch all the way to the left next to the signal meter up once to SWR.
The needle should swing back giving you your SWR reading. Ideally you want this reading to be as low as possible, but 1.5 and under is acceptable. If it is higher then 3 and in the RED stop transmitting. Try to do the steps quickly so you can un key as soon as possible to avoid damage to the final resistor if the SWR is higher then 3.
If the reading is 1.5 or under and the ant light is going on, it could be something else. I will go more into this at the end.
Now we have to figure out if the antenna is too long or too short. Here is how to do this.
Turn to channel 1 and repeat the steps to take an SWR reading. Make note of the reading.
Turn to channel 40 and repeat the steps again to take an SWR reading. Not that number.
If the SWR is higher on channel 40 then channel 1, then your antenna is too long and you need to adjust your antenna so it is lower.
If the SWR is higher on channel 1 then on channel 40, then the antenna is too short, and you need to adjust the antenna higher.
If the signal is over 3 on both channels, then there is something wrong with either your coax, antenna or both, and you should replace the coax, and if its still high, the antenna.
If your antenna is too long or too short, make adjustments to correct. Raise or lower the antenna a 1/4 inch at a time. each time taking a measurement to see if it is still to long or too short. You want to try to get the SWR the same on 1 as on 40. And channel 20 will have the lowest reading.
If your SWR reads low, under 1.5, or even a 2, the light should not come on. If you have had the radio worked on at a radio shop, or purchased it from some where that modifies the radio to put out more power before they sell it, then that can cause that light to go on falsely. Purchase an external SWR meter. You can get one off ebay, or from radioshack. Check the SWR with the meter, and if the SWR is still good, then you can do 1 of the following.
1. ignore the light because it is not right.
2. go in the radio and try to adjust VR6 so that the light doesn't go on. Not recommended if you don't know what you are doing.
3. take it to a cb shop and have them adjust VR6 for you.
I would leave it alone.
Most likely your antenna is not tuned properly.
SOURCE: when i key up the mike the tx/rx light and the ant
your swr setting are off wack fix your swr
SOURCE: Red RX/TX and red ANT light on my CB
Well,first hand ,some cobra radio,s have red some have green RX/TX lights, but are you modulating? Some green lights turn red. What is your standing Wave on the antenna,s? You need to check it and the output of the radio. To do this you need a watt or field strenth meter. Can get one at Radio Shack. Your standing Wave is ok as long as it is below a 2. That has to be done on the antenna. ..hope this helps...
Testimonial: "Thx the rx/tx light is supposed to turn red I found out. Still trying to get the antenna prob fixed though."
SOURCE: red antenna warning indicator light stays on
The red light is a warning of antenna mismatch; when you hold the antenna, you are changing the match between the CB's output amplifier and the antenna. Try it with a different antenna or pick up a 'test light' (or test load) for CBs from an electronics dealer, I've also seen them with CB accessories at truck stops. If the test light fires off and the red light on the CB is dark, the antenna you have is junk.
