Maytag old...about 20yrs.... will fill up... when it comes to spin cycle to drain its like there no pressure from the pump.... if you put the drain hose low the water will drain out of the machine ...no probs.... not sure if i need new belts... or the pump is killed...but it seems ok....the motor seems fine... help please....thxs ( ps cant give you model number(a2125)...its a top load washer)
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
