Question about Kyocera FS-1118 Printer
Please help the print on the page moves up and down on the page
Print moves up and down on the page
The printing goes off the page
pls set the paper size to the actual paper size you load.. you have probably selected legal size in your pc and load an A4 size paper onto the printer...
May 26, 2010 | Epson LQ 300+ Matrix Printer
Print issues
Look at the fuser, and see if you can see a bad area on the fuser roller, matching the position on the paper. I suspect a bad fuser. Fusers need to be replaced periodically, and typically via a maint kit which replaces several feed rollers as well.. How many pages have been printed.. Print a config sheet to display this information.
Nov 04, 2008 | HP LaserJet 3030 All-In-One Printer
Text moves down the page when I copy - how can I stop this?
Sounds like it is either resizing the image or not seeing all of the original.
Specify the original size and do not use auto.
Make sure thsat image shift or image centring is not on.
Jun 16, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
Canon MP730 won't print at all (blank pages).
try to move the blue nozzel over the printing head to the from the right to the left and try, it will work
Feb 03, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
HP 2420 sudden prints pages in all black
Most likely to be the toner cartridge is it OK on other programs such as the web explorer? If not change the toner cartridge you can also print out the configuration page by pressing the green tick and then using the up and down arrows select information press green tick to enter then move to "Print Configuration" and select using the green tick. If the page comes out OK then the print cartridge if fine if not try changing it. Also there maybe in the driver you have under printing preferences negative mode make sure that is not checked.
Failing this reinstall the print driver from HP Online if this still doesn't work then change the data cable if still not working then I suggest that the printer formatter board is faulty.
I do hope this helps you and please rate me
Thanks J
Dec 30, 2007 | HP LaserJet 2420 Printer
HP Laserjet 1100
Try selecting the image you want to print by holding the left mouse button down and moving it over the text once you have done that goto file print select the correct printer half way down you should have page, pages, or selection choose selection and then print.
Hope this is of help to you please rate me
Cheers J
Nov 19, 2007 | HP LaserJet 1100 Printer
How to align my paper
Remember- When ever u remove the carts form the carrier...u need to print an alingment page....(Start-programs-lexmark-solution center-maintenence -Click on "align to fix blury edges"..
For Paper jam
Check if any particles have fallen inside the printer...
Try to move the cartridge carries manuelly....move the roller...
Turn the printer up side down and shake it well but be carefull
Nov 17, 2007 | Lexmark All-in-One Printer with PictBridge
Deskjet HP 6940
this might be a software problem also. please specify which software you are using to print these banners. Thanks
Jun 12, 2007 | HP Deskjet 6940dt InkJet Photo Printer
White line across printed page
Hi Alms, Is there any chance you can post a scan of one of your faulty pages. This would help to assess the fault. If you print several pages, does the image move further and further down the page with each copy? Is the white band repeated down the page? If so measure the distance between each band - this will help identify the faulty component.
May 21, 2007 | Minolta magicolor 2200 DeskLaser Printer
Kyocera FS-1118 Printer Logo
15 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Marvin
Marvin
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
