Question about Mtd Garden
MTD Mastercraft rear tine tiller transmission problem
I bought this tiller used and the guy installed a new shift fork and when he had it all back together it would'nt move. I got it home and tore it down and he had a few gears and spacers out of place, i got it back together and it will move forward and reverse and the tines turn, but as soon as i put some resistance to the wheels (like pull back on the handle bars when its moving forward) it stops and it sounds like a base ball card against the spokes of a bike inside the the transmission.
    Top Expert:
  • Mtd Master
  • 53,770 Answers
Adjust the spring tension on the ratchet assembly as you are supposed to be able top pull it back against the drive action
Posted on May 29, 2017
Anonymous
SOURCE:
Tom
  • 221 Answers
SOURCE: I have a MTD yard machine rear tine tiller. Goes
You will have to get into the gearbox. It isn't too hard but is time consuming. Sounds like the drive for the tiller has broken. Could just be the chain in the gearbox for the tiller drive.
Posted on Jul 01, 2010
Anonymous
SOURCE: tines wont turn
Without really knowing what is broken it will be tough to give a firm idea of the cost. However, you can head over to www.partstree.com. They have a great detailed parts break down and costs associated with it. Looked up your part numer and can find at this link: http://www.partstree.com/parts/?lc=mtd&mn=210-031-000+%281990%29
Posted on May 07, 2009
MNfisherman
Nate Stansfield
  • 11896 Answers
SOURCE: MANUAL FOR 1994 MTD TILLER
www.ereplacementparts.com/mtd-215412000-1985-tiller-parts-c-20039_20363_20380.htm
Posted on Jul 09, 2009
Anonymous
  • 205 Answers
SOURCE: Tiller goes For./Rev. but wont drive forward with tines engaged
check the sher bolt on the tine to drive shaft. ill need model and ser number off the unit before i can go further with helping you thy changed them around a lot
Posted on Oct 13, 2009
Tom
  • 221 Answers
SOURCE: mtd rear tines tiller won't engage tines. F and R
It sounds like the shift shaft or something in the gearbox the shift shaft engages. I know you didn't want to hear this but it is not uncommon. Most operators don't use the clutch bail when starting, stopping, and shifting as they should.
I hate to say it but this may require a trip to your service center for repair.
Posted on Apr 30, 2010
Have a MTD Yard Machine rear tine tiller Model 410 and when I went to use it this year when I put it in gear the tines did not move. I called the MTD tech and he said it sounds like its in the...
It is the shift fork in the transmission. Bad part design and if you plan to take it apart, use sandpaper and really clean the wheel axle and tine axle before you take it apart.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/thomas_d71920e629f739cb
Mar 20, 2011 | Mtd Garden
Mtd rear tines tiller won't engage tines. F and R
I had similar problem recently with 2007 Huskee MTD series 410. The shift assembly bent and couldn't move the clutch collar all the way over on the drive shaft.
Apr 23, 2010 | Mtd Products Yard Machines 158CC Tiller
MTD Series 410 rear tine tiller. Tines won't engage.
I had the same problem. After splitting the case, I found that the shifting fork was bent and the pins that move the shift collar were worn. I made new pins for and reinforced the shifting fork, put it back together and if worked for a few minutes until it would jump out of gear while tilling. I would try to hold the external shifting rod down so that it would not jump out of gear but eventually it quit working completely. I tore it down again and the pins were already work out. I ordered a new detent ball and spring for less than $10 including shipping. This seems to have cured the problem. Apparently the detent spring was weak which allowed the shifting collar to disengage from the drive gear when under load. The original spring had been replaced with a new part number so it may have been made stronger. Tearing one apart is not easy but is certainly doable. To make it easier, put the nuts back on the bolts from where they came. Also get the parts manual picture to help with reassembly. Be careful with the case gasket. It costs a ton for a new one but since the grease is so thick, you could probably silicone it back together if you destroy the gasket.
Apr 19, 2010 | Mtd Garden
Have a rototiller it moves OK but the tines do not turn It is a mtd yard machine rear tine
Seems to be a fairly common problem with these units. If the big pulley is turning which I assume it is as the drive wheels work, it is most likely a problem in the gear box. The shift mechanism in these units leave a lot to be desired. You can try to repair it your self or take it to a service center. Labor will be high due to the amount of time required to separate the engine and transmission.
Apr 18, 2010 | Mtd Products Yard Machines 158CC Tiller
Yardman Rear Tine Tiller tines won't turn. Belt and tenson good. Belt will drive rear wheels in forward or reverse but tines will not turn. when I trun tines by hand nothing seems to be turning in the gear...
The problem lies in the shift lever in the gearbox. A poor initial design that was upgraded twice. The shift fork arms have spread enough for pins to come out of the groove they run in when the tiller is shifted to the last position. (Bending back into position would only be a temporary fix as would not be any stronger.) To replace shift lever, the gearbox cover has to be opened. Seperating the cover can be somewhat challenging. When prying cover apart try to not damage the cover gasket. Gearbox grease is very thick, so gasket's real purpose is to keep water and contaminants out. Leave all gearing and chains in place. The shift lever part number is 618-0245B. Or use assembly kit number 753-0869 (contains shift lever 618-0245B, position indicator, and roll pin.) Part will run in the $56-$68 range and can be found through MTD as well as Cub Cadet. Also can get through Sears PartsDirect.
Jul 26, 2009 | Mtd Bronco Rear Tine Tiller
Belt seems to be slipping
good evening. I would suggest checking the tine bearings as well alignment. I had (have) a 2003 mtd rear tine which blew the entire bearing box for the second time. The times should have little to no flex when push or pulled. Fortunately, MTD came good for the first rebuild even though my warranty had expired...they covered the parts and labour was all mine. If the tines seem properly working, possibly try out this website to get the 100% correct belt....hope this helps.
http://www.milacalawn.com/parts.asp
Apr 17, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Tiller tines won't turn where put in gear.
The spring goes in first followed by the ball. The ball should not get in the key way because that is filled by the slider pins that go up into the spur gear that drives the tines. Actually the slider pins drive all of the gears by engaging different gears as the gear collar is moved up and down. The detent spring and ball is the mechanism that is supposed to hold the the clutch collar in place. Mine jumps out of gear when tilling any depth except very shallow. I have reinforced the shifting forks and replaced the pins on the end of it. I believe that the pins wear and the arms spread because i have to keep pressure on the shifting rod or it will jump out of gear when tilling. Even with the reinforcing, pressure on the shifting rod will wear out the pins on the shifting arm. This will be my 3rd reassembly and I am leaning toward the detent spring being weak and allowing the shifting collar to move too easily. I may order an new spring and ball and see if that helps. I am getting pretty good at taking it apart.
Mar 18, 2009 | Mtd Bronco Rear Tine Tiller
Yard Machines/Tiller
the tines are usually connected with shear bolts designed to break away when u hit something as a safety precaution so that u dont break anything in the transmission. its common that people dont know this and replace them with normal bolts. if this was done and the tines are not moving now chances are uve got a snapped gear shaft
Sep 28, 2008 | Mtd Super Bronco Rt Tiller
Garden Logo
7,905 people viewed this question
Top Mtd Garden Experts
dannydoesita
Joseph Mueller
Joseph Mueller
p38arover
Level 1 Expert
Are you a Mtd Garden Expert? Answer questions, earn points and help others
