WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Make sure that your RAM modules and Cmos battery are securely seated
on some motherboards Cmos batteries are soldered in.
Test all power and data leads that attach from Motherboard to your Hard Drive I SATA
That beep code is for a ram falure Unplug PC from the wall and press/hold power button on tower for ~15 sec. Open the case, chase out all the dust bunnies and carefully reseat the RAM modules in their slots. The first 64K are on the module in slot 1. If it still won't boot, unplug, and press the power button again. Remove the module from slot 1 and swap in the module that was in slot 2, leaving second slot empty. If it boots, then the first RAM module failed and has to be replaced.
