Question about Fisher and Paykel GWL11 Top Load Washer
My Fisher and Paykel washing machine beeps every second and shows the following code 1&2 off, 3,4&5 on, 6,7&8 off. Have removed agitator and checked pump for blockages. Sometimes will do a full cycle no probs. have checked and cleared auto fill hose. Will sometimes spin, sometimes not. Sometimes wash, sometimes not.
    Habit-Forming:
  • Fisher and P... Expert
  • 199 Answers
Each light has a specific number, so to work out the error code we need to know which side you are counting from i.e. left to right or right to left. Makes a huge difference.
Posted on Oct 14, 2017
6ya staff
SOURCE:
aborcass
Ron Coons
  • 2651 Answers
SOURCE: paykel fisher wash problem
its possible, depending on problem with unit, if youd like you can acess a tech sheet behind the console,theres a pretty good desription of common troubles encountered and fix it solutions.
Posted on Feb 27, 2008
Anonymous
  • 145 Answers
SOURCE: Fisher Paykel washing machine model # GWL15 drips
Hi Dale..
It sounds like you have a leaky inlet valve assembly. The part number is 421029P and is easy to replace. You can get one here:
http://www.fisherpaykelparts.net/ecart/item.php?item_id=266&category_id=56
Posted on Apr 20, 2009
Anonymous
  • 10 Answers
SOURCE: Fisher & Paykel GW612 Top Loading Washing
Hi there
That fault is the pump blocked error (no change in water level).
i have a quick and easy way to solve this problem.
first turn the machine off then tilt the machine back and lean it on something(a chair or wall), look underneath, in the top right hand corner of the plastic outer boul you will see a small pump motor it has a fan on it spin this fan and if it is hard to turn that means there is somthing stuck in the drain pump keep turning the fan and try to free whatever is stuck in the pump, then try the machine on spin again all goin well the object in the pump should come out with the drain water(doing this will not harm the machine) if the object is still stuck you will need to get the water out of the machine (bailing or siphioning will work) and tilt the machine back again and take the wires off the pump and there should be a white tab on the boul holding the pump on pull this tab and twist the pump anticlockwise about a quarter turn(you will need a few towels or a boul or bucket to catch the water) and it should come off exposing the blockage.
Hope this solves your Problem.
Nick
Posted on Aug 03, 2009
luisa_sgro
  • 713 Answers
SOURCE: fisher and paykel washing machine becomes
i think that 1 or more suspension rods r faulty. lift the lid and at the front of the machine u will see 2 plastic covers, remove the covers and undo the screws underneath. now lift the front of the hob up gently and u will see the suspension rods. they r easliy replaced. but first see if they havent just popped out. if they have just popped out look at the other 3 and refit to how the others are.if u need more help or u find another problem reply back and i will help u more.good luck
Posted on Apr 24, 2010
luisa_sgro
  • 713 Answers
SOURCE: washing machine stopped during spin cycle
Hi just read your posting.Now on the wash progress line of lights ,there will be 8 in this row.Starting from the left to the right which lights are lit.Is it the 2nd ,3rd and 7th or the 1st, 4th and 8th ---etc---?Please reply with additional information and I can help you rectify this fault on your machine.Looking forward to your reply
Posted on Jul 27, 2010
Fisher and Paykel washing machine spins but will not agitate. Why?
Because something is wrong with it. What is wrong? Who knows because you haven't told us what model and what happens when it has filled with water (assuming it has). Is there any beeping and any error code showing? If you want help you have to first help yourself by giving as much info as possible. We are not there and can't see what is happening.
Dec 31, 2016 | Fisher and Paykel Washing Machines
Soap residue fisher & paykel top loader
Agitator can be removed easy,Take out the fabric dispenser cup,
Reach down inside the agitator & undo the wing nut, left to undo.
Take out agitator & clean & the bottom of the bowl,
For a more better clean fill machine with hot to high water level & leave soak over night,Do heavy duty wash in the morning to remove scrud.
Feb 10, 2013 | Fisher and Paykel Washing Machines
Fisher and Paykel GWL11 Top Load Washer starts but drum won't turn, it twitches and beeps then turns off with solid beeps
Hi ken
Can you turn the bowl & agitator by hand.
If it can't turn by hand, Your seal & bearings need replacing.
Feb 01, 2013 | Fisher and Paykel GWL11 Top Load Washer
Fisher Paykel GWL 15 Rotor Position Sensor
Does It just shake bowl left & right, it will soon give you fault code 56.
Well its a board problem you will need to get technician to fix this board, three resistors(R129,R130,R131) need to be changed for a 1MegOhm resistor.
Jul 08, 2012 | Fisher and Paykel GWL11 Top Load Washer
MW511. 2 & 7 lights flash, beeping. No agitate or spin?
Fault code 66 is pressure sensor is faulty
66. (01000001) Pressure Transducer Error [Ptx Frequency > 90 kHz]
Note: this supersedes Fault code 65 from V41 Motor controller code onwards.
The Motor Control module has received signals from the water level sensor (Ptx)
above normal frequency values.
Primary Source: Motor Control module
Action: Replace Motor Control module
Apr 20, 2012 | Fisher and Paykel Washing Machines
Something is stuck underneath the agitator in m Fisher & Paykal Aquasmart. How do I remove the agitator?
Hi - with aquasmarts there is a plastic dome like fitting in the middle of the agitator & unscrew this to remove the unit.
Jul 08, 2011 | Fisher and Paykel WL37T26D Top Load Washer
Hi I have a Fisher & Paykel MW612 top load washing machine. It will start to fill normally on warm wash then the hot stops coming in and the cold fills intermittantly then the whole ting stops and...
Gary - LEDS 00110010 as you have not mentioned the last LED which will be red if on is 00110011
Ok - your code is 50 indictes a faulty hot water valve - question - have connected the hoses correctly - as per your descriptions - it should always be cold 1st then hot water- cold - then hot etc until it fills.
Pays to check this as the fault code is totally opposite to what your saying..
May 01, 2011 | Fisher and Paykel GWL11 Top Load Washer
Machine fills and starts to agitate, then stops. Will pump out & spin but not agitate. Refills with way too much water. Continous 1 second beeps. All lights on or 2nd, 3rd & 4th from left. Not...
Hi just read your posting.Could you please confirm the lights that are on when the machine is beeping as the lights you described that are on is not an error code.Also please confirm the model number for me.It is on s sticker at the back of the machine top left.Looking forward to your reply.
Sep 26, 2010 | Fisher and Paykel Washing Machines
Our F & P GW508 Smart Drive starts to fill at
Sounds like your out of balance switch is corroded. It is located underneath your gold motor controller board.
May 27, 2017 | Fisher and Paykel Fisher Paykel Intuitive...
Open Questions:
See all Fisher and Paykel GWL11 Top Load Washer Questions
Fisher and Paykel GWL11 Top Load Washer Logo
140 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Archie Ferrarini
Archie Ferrarini
Gerry Harvey
Gerry Harvey
jimorris77
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
