check the lamp ballast
any questions, feel free to contact me
We supply original projector lamp,bulb,accessories,Lcd panel,Lens,DMD
chip,color wheel,motherboard,powersupply,ballast... with high quality and
competitive price.
have a nice day!
Jerry,Lampdeng Limited
Hello Look at the number of blinks of the status light. [1] If it blinks at one cycle (0.5seconds On and 2.5seconds OFF) : Lamp cover error or lamp housing error. Replace the lamp cover or lamp housing correctly. [2] If it blinks 2 cycles (0.5 seconds ON and 0.5 seconds OFF): Temperature error. The projector is overheated. Move the projector to a cooler position. [3] if it blinks at 4 cycles (0.5 seconds ON and 0.5 seconds OFF): Fan error. Fans sill not work correctly. [4] If it bliks at 6 cycles (0.5 seconds ON and 0.5 seconds OFF): Lamp fails to light. Wait a full minute and then turn on again. [5] If it blinks continous (Red): Lamp has reached the end of its life. Lamp replacement messege will be displayed. Replace Lamp with same type and number. After replacement reset lamp hour. OK.
One question, why you decided to replace lamp in tv? Did tv showed red lamp light blinking? Suggestion, make sure lamp cover has been placed back in its position after lamp replacement, lamp cover is first thing that you removed from tv cabinet to take out lamp.
When was the projection lamp last replaced in this tv?The projection lamp in the tv now is about 1 1/2 or 2 years old and the tv been on and watches like 4 or 5 hours a day?The projection lamp life is over.Require a new projection lamp.
If lamp light is on at tv front then replace lamp as existing lamp sounds dead/ broken. Lamp replacement procedure would be written in user manual of tv. And if lamp light is not on but standby light is blinking then let me know how many times it is blinking to find out problem cause as standby light blinking is an error code.
the 3 blinking LEDs mean the lamp may be defective. Be sure the lamp is making contact with the sockets within the lamp compartment, also make sure the lamp is the correct one for your model. The set can be reset by unpluggimg the power cord for 5 minutes then plug it back in, if the 3 LEDs still blink check the lamp if its making contact and its the correct lamp for your model, suspect the ballast
It is symptom of weak Lamp in your TV, replace Lamp with following part number.. A1606034B
LAMP BLOCK XL-2100U It is available in Sony Accessories for $200 Always buy Sony Original Lamp for your Sony TV and avoid aftermarket/ cheap lamps.
A 5 blink code is a lamp power supply problem, but I would try a new lamp. I'd say about 90% of the time that fixes the problem.Get an ORIGINAL Sony lamp as the aftermarket replacements are ****. If you replace the lamp and still have the problem, you will need to have the lamp power supply/lamp ballast replaced
Having similar issue with my PT-44LCX65. Lamp blew and replaced it (last month), never figured out how to reset timer. Now red indicator light blinks once every 5 seconds and after about 4 minutes TV goes black.... Any ideas?
