This model belongs to Samsungs compact camera series It has 7MP sensor which at time offered lot of megapixels to average consumer ensuring great quality of photos at large...
WIFI connection method:
1. Switch the power button to turn on, then long press the play key until the blue light on(30 seconds later, blue indicator light start flickering, then the clock camera is turned on , and then red indicator light will flickering, which means the clock camera WIFI signal is opened)
2. turn on the WIFI on your smart phone . Run APP software that you have downloaded and installed
I have had a similar problem. My solution was to check the zoom button. It seems that when it is "out of range" you can do nothing with the camera. Try to adjust the zoom a Little bit and you will probably be "in range" and the camera with work.
the ac clutch will quit working if the refrigerant pressure drops too low ... or if the pressure sending switch is bad or if the wire to the clcutch is broken .. the word "frozen" usually means it cant be turned (not that it just doesnt turn) ... if you cant turn the unengaged clutch then thats a compressor failure ... that may in turn damage the clutch as it slips trying to turn the frozen compressor .. if the compressor can be turned freely by hand then thats not the problem .. if the clutch is simply not being turned on then usually thats just low refregerant or a blown fuse, bad relay or bad low pressure switdh . once in a while there might be an open winding on the clutch or a broken wire going to it .. they cant check refrigerant pressure without first getting the clutch to work ... so its possible to jump power directly to the clutch .. it will usually operate and gauges applied to the air conditioner might show the pressure to drop very low .. that would normally turn off the clutch ... just checking for leaks and recharging often is all that is needed ..
This just happened to me last night. Literally, the EXACT same thing. Here's the sollution:
Wait 'til your camera has run out of chage, it will then turn off. The camera lens will still be sticking out, though. Once it has turned off, take your charger, plug it in, and then charge your camera. Once the charger is actually in the camera itself, it will turn on and resume its' normal mode. :)
I had the same problem - and wondered if if might be that the battery didn't have enough 'grunt' to close the lense - so I am charging it via the actual charger (rather than through the computer) and sure enough, I turned it on and then off, and the lense closed. The green light comes on when I plug the camera into the computer to download photos, and I thought this was therefore charging the battery, but maybe it doesn't charge it properly. Anyway, my lense is now closed and the battery is still charging (light is still red). Good luck.
your lense is jammed try to put your finger in it and close the lense all the way it might me like hardly closed, i had that problem and now my is open all the way so i cant close it yuo can email me at [email protected] or im makaluso06
