Question about Acoustica Mixcraft Pro Studio 5
Error bad elk - Acoustica Mixcraft Pro Studio 5
I lost a pair of Winchester VDT 1042 field glasses about 8 years ago. found them today in the pasture. They appear to have condensation in them. what can I do to get it fixed and how much?
Hello, Raymond -
Congratulations on finding your field glasses. I checked the Winchester.com web site to see if they offered repair services for their field glasses / binoculars. I did not find that they manufactured field glasses . . . meaning they are probably not providing repair services, either. I assume you are in the USA.
I did find a business located in suburban Chicago, Illinois, Elk Grove Village. Among many things they repair they state they repair "optics", including binoculars. I suggest you call this company and ask about repairing your field glasses:
United Camera Service Center
2525 Busse Road
Elk Grove Village, Illinois 60007
Toll Free: 866-488-8227
Best wishes
Dec 18, 2017 | The Optics
Is a elk bigger than a caribou
Elk males (700lbs)are generally 200lbs more than Caribou males(500lbs).They get very large and are just a bit smaller than average horse(+900lbs).
Mar 06, 2015 | Cameras
I have a horn that sounds when my hay baler chamber is full. I am looking for a timer relay that will allow the horn to sound for 3 to 5 seconds and then disconect the circuit so it won't drive me...
DEI 528T appears to be 12Volt 'wait to start' or ON-delay timer.
528 receives electrical signal, and then delays the start-circuit by up to 60 seconds.
For example home alarm system. Door is opened and alarm sounds. Install DEI 528 and set for 60 seconds: Door is opened and alarm will not sound for 60 seconds.
You need 12-volt off-delay timer.
Off-delay timer receives electrical impulse, and then begins a countdown.
After countdown expires, then circuit turns off.
ELK-960 appears to have off-delay feature for 12V DC
http://www.homesecuritystore.com/p-423-elk-960-delay-timer-module.aspx
Use wiring diagram #7 for alarm cut-off:
http://download.homesecuritystore.com/downloadmanual.aspx?FileName=ELK-960_Install.pdf
Aug 25, 2011 | Directed Electronics Dei 528t Pulse Timer...
Hoeveel bar moet de bandspanning van een ktm sx uit 2003 zijn? Hoe vaak moet je de luchtfilter vervangen?
Jy kan die bande 2.3 bar (230 kPa) maak vir asfalt, 1.6 vir offroad, jy sal voel as dit te slap is op asfalt. Moenie veel meer as 2.7bar gaan nie.
Ek het op my XR500 Scrambler die filter elke tweede maand, omtrent elke 4000km, vervang want ek het baie offroad gery.
Jun 18, 2009 | 2003 KTM SX 125
Manual easy lock 804
Copy this entire link: http://web.archive.org/web/20060508095821/http://www.simplicitysewing.com/ftp/whitepapers/804.pdf Enjoy!
Apr 04, 2008 | Simplicity Serge Pro SW432 Mechanical...
Wii Set up
hi elk man did you connect the sensor i had the same problem this morning
Dec 25, 2007 | Nintendo Wii Console
Acoustica Mixcraft Pro Studio 5 Logo
226 people viewed this question
Top Acoustica Computers & Internet Experts
Ekse
Marvin
Marvin
Are you an Acoustica Computer and Internet Expert? Answer questions, earn points and help others
