My Router "COMPEX NETPASSAGE 27G" was not working on reset. What the problem i found is when i try to configure router with the IP: 192.168.168.1 in browser, it say page cannot open. Several times i had tried to reset even it was not responding. When i try to ping the router it was giving reply and the Wi-Fi is fully functional and blinking 1 flash per sec. Then i try to update its firmware using "tftp -i 192.168.168.1 put
Problems: TFTP, DHCP, HTTP are not functioning in the router. Is there any master reset for it. Kindly send me a solution.
Waiting for your reply...
Nandu..
+91-9885129859.
192.168.168.1
is not the routers address.
try
192.168.1.1
also, firmware for the router ends with .bin
The firmware is an .img file
your routers default gateway is 192.168.168.1
sorry
your default password for your router is password
To reset the router,depress the Reset button (at the back of the router) when the router is powered up and
hold the button for 8 to 10 seconds before releasing it.
I am unable to surf the Internet.
A. Make sure that your Ethernet cable is properly connected from your Cable/ADSL modem to
the router’s WAN port, and verify from the About System page if a valid IP address (from
the ISP) is shown under the WAN port section.
B. If not, ensure that your WAN settings correspond to the type of broadband Internet
connection you have subscribed to. You may contact your ISP to see if your Internet
connection type: is Dynamic IP, Static IP addressing, PPPoE (commonly used for ADSL
subscriptions) or PPTP. Please refer to Part 2 of Chapter 4 for WAN Setup. Remember to
reboot the router after changing your WAN settings.
C. If you are able to surf the Internet when your Cable/ADSL modem is connected directly to
your PC, but after setting up the router and verifying the settings in steps A & B above, your
router is still unable to get an IP address from the ISP, then you may need to refer to Chapter
4 Part 2(d)i steps 5-7 to clone the MAC address of your Ethernet adapter onto the router.
D. If all configurations from the above points A to C have been followed, power off the
computer, the router and the Cable/ADSL modem. Turn on the Cable/ADSL modem, then
wait for a period 1 minute before turning on the router. Lastly, turn on your computer.
Verify again if you received an IP address and attempt to surf the web.
E. If you are a PPPoE user, you will need to remove the proxy settings or the dial-up pop-up
window.
For Microsoft Internet Explorer 5.0 or higher, start Internet Explorer, from the Tools menu
bar, select Internet Options and then click on the Connections tab.
o From the Connection tab, click on the LAN Settings button. Uncheck any options
from that dialog box. Press the OK button to return to the previous screen.
o Click the radio box option Never dial a connection to remove any dial-up popups.
Press the OK button to finish.
For Netscape 4.7 or higher, start Netscape Navigator. From the Edit menu bar, select
Preferences, then Advanced, and finally Proxies.
o Make sure that the Direct connection to the Internet option is selected.
o Close all windows to finish.
The firmware is corrupted and I can’t access the router’s “Firmware Upgrade” page anymore.
H. Verify the Diagnostic LED. If it keeps blinking rapidly, you will have to perform a manual
firmware recovery procedure. First, power OFF your router. Except for your PC, disconnect
all other networked devices from the router.
I. You MUST give your PC a static IP address of 192.168.168.100 with a subnet mask of
255.255.255.0.
If you are using Windows 98SE or Windows Millennium, follow Part 1(c) on page 14 of the
manual to set the static IP address.
If you are using Windows 2000 or Windows XP, follow Part 1(d) on page 15 of the manual
J. Insert the Product CD into the CD-ROM drive of your PC, where the CD-ROM drive is X:\,
double-click “27grcv.bat” to begin the firmware recovery process.
K. It takes about 1 minute to complete the whole process. Slower blinking of the Diagnostic
LED will indicate this. Power OFF and then power ON the router to continue with normal
operation.
let me know if this helps you.
thanks
Did this work?
Please post an answer so we can help you further.
If it worked please rate this post as solved.
Thanks,
Thanks Tom for trying but as i told above problem the company default ip is 192.168.168.1.
