Canon PowerShot Pro1 Digital Camera Logo
A
Anonymous Posted on Apr 18, 2014
The photo is so bright
When I try to zoom in the lens captures light and the image becomes so bright. When I take photos without zoom it is normal
5 Related Answers
Anonymous
  • 10 Answers
  • Posted on Sep 14, 2007
SOURCE: Canon powershot A85 photo capture problem
Sencor is bad,I have repair this before.
t00nz
CameraR
  • 4738 Answers
  • Posted on Nov 16, 2007
SOURCE: Screen all fuzzy when taking photo.
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110
A
Anonymous
  • Posted on Aug 13, 2008
SOURCE: black screen, not capturing photos
have the same problem...
it happened about a month ago and i pressed the display button and it worked, but now that doesn't work either!
Anonymous
  • 34 Answers
  • Posted on Aug 28, 2009
SOURCE: Canon Powershot broken shutter/photo taking mechanism?
I hope you didn't chuck your camera, because this sounds like a problem with the CCD image sensor. I had the same problem with my Canon A85 and found out that Canon would cover the shipping and repair of the image sensor for FREE.
Please refer to this page, and then contact Canon (I reccomend calling; they're friendly, and the wait is not too incredibly long) to describe your problem. Make sure to mention that you believe the CCD image sensor is faulty, and you found the service notice they issued about the problem:
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=221&modelid=10462&keycode=2112&id=48264
t00nz
CameraR
  • 4738 Answers
  • Posted on Feb 20, 2011
SOURCE: MY CANON SHOWS THE 'LENS
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
1helpful
Camera not displaying images as seen through viewfinder. The screen is black. Image controls and info can be seen but the picture is just black. Takes photos which are also black; but previous photos...
A stuck shutter is another common failure mode for digital cameras, particularly for the SD1000. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
By the way, my wife's SD1000 also has this problem every once in a while. I easily fix it by using the following steps from the link: powering on the camera, opening and closing the battery door, and flicking the end of the lens barrel with my fingertip (or you can tap it with a pencil as discussed in the link).
If i click for photo in day its too brightness because of that i we cant see images properlly please ressolve my problem !!
Turn off your flash light manually and avoid to capture with strong light in front of your lens (sun or lamp)
When you take picture outdoors with much light, try to shade your lens with something, use umbrella or even your own hand shadow to make a shade.
If useful, RATE please !
At the time of photo taken in zoom please instruct me actual shutter speed & exposer in which better photo is taken pranab
Pranab, When using a zoom or telephoto lens, it's just like using a telescope - a little bit of movement in your hand makes the image jump around a lot. If you take a picture under these conditions it is often blurry. There are 5 things to improve the image quality: 1. Use the fastest shutter speed possible. 2. Since a fast shutter speed captures less light, you also need a wider aperture (that's the size of adjustable curtain in the lens known as the f-stop, a smaller f-stop number indicates a wider aperture). The wider aperture allows more light in. 3. Use a tripod. This works for telescopes and cameras. 4. Bright available light. On a sunny day, there is lots of light available, so you can use a fast shutter speed and still get enough light. 5a. On film cameras use "fast film". This film is more sensitive, meaning it requires less light so you can use a faster shutter speed. 5b. On some digital cameras there is Image Stabilization. The image is electronically stabilized - this is like using a tripod to hold the image still, while allowing the camera to move around a little bit. I hope you found this helpful good luck Al K
Jan 12, 2011 • Garden
I'm having Kodak C190 digital camera. I'm facing certain problems which are as follows:- 1. My camera is not able to capture photo of moon even in night mode. it becomes totally blurt. 2. which one of them...
Pictures of the moon require a tripod. Night mode is a good starting place. After taking a test picture, if the moon seems too bright, you need to set the "exposure compensation" to the next lower number. Take another test photo and adjust as necessary one way or another. After you get a successful photo, you will need to crop it a lot to get the moon large enough.
When i take a photo in day time images becomes very brigh
the camera,diaphram is defective so bright light exposes,will be over exposed.
1helpful
Dropped Nikon Camera Sadness
Hi Al
not sure if i can help here but will try.
Ive not owned the D50 but i have the feeling the highlights function is similar to other cameras in the Nikon range.
On your cursor when viewing an image, just press down on the cursor maybe once or twice to remove the highlights .This is just a pointer for you like the histogram.
Now it seems like you may have damaged the sensor and will not collect enough light.
Try setting the camera to A = aperture priority and take a shot in bright light...no flash.
Are the images still dark ?
If so raise your iso to 800 and shutter speed to 1/250 at F5.6 aperture in mode S =shutter priority and take the shot in bright conditions.
Are the shots still dark ?
Missing shot.
Any auto camera like this is going to have trouble in dark light...
Photography is all about light, and in dark situations, compromise as well.
You best chance is to set the ISO up to the highest setting available, use flash, and a faster shutter speed, however, faster shutter speeds means less light can enter the lens, and hence give a darker image. Higher ISO makes the camera more sensitive to light, but produces grainier images as a result. Flash creates artificial light...
The only real way to get good images at a concert in the dark is with a high end camera, a lens costing many thousands of dollars, a tripod or monopod to steady yourself, and a longer open shutter time.
In the meantime however, experiment with higher ISO setting, flash and try to keep your hand steady at all times because the shutter speed needs to be slightly slower for the lens to capture more light.
2helpful
2answers
Ricoh XR-10 35mm SLR camera
stevdan,
take the screws off the bottom cover. there is a small lever pointing toward the front of camera with a black screw on it. gently move it to the left, this will release the lock lever. Now advance the lever and the shutter should fire. if not, it is not repairable. no parts
Low light photos
It depends.
If you want to shoot static content eg. landscapes in the afternoon etc., you need long exposure times and of course a tripod. If your lens has image stabilization, do not forget to turn it off while you mount your camera on the tripod.
The other thing you can do, but it will cost you money, is get a brighter lens, (eg. F2.8). This combined with Image Stabilization will give you more freedom to capture moments in low light conditions, as a brighter lens can give you a brighter result without having to increase ISO.
Finally, another cheap method is to increase ISO. Of course this brings noise into the picture. Up to ISO 400 you may not notice the difference, but if you go higher, you will. If we are talking about point and shoot photos that you are going to print them on normal photo dimensions, a certain amount of noise won't be noticeable.
Hope this helps.
Feb 28, 2008 • Cameras
Why do my Fun! Digital 320 pictures come out blurry?
Blurry images can be caused by any or all of the following: * Distance/Focus range -- the Fun! Digital 320 has a fixed focus range of 3 - 6 feet (1.8 meters) for brightly lit indoor photography, 3 ft. (1 meter) - infinity for outdoor photography. For best results, make sure that the camera is at least 3 feet away from the subject(s) when taking pictures. * Camera/Subject movement -- This is a common cause of blurriness, especially in low-light situations (see Lighting below). Hold the camera as steadily as possible while taking a photo, or use a tripod (a tripod mount is located on the bottom of the camera). Avoid subjects that are in motion. * Insufficient lighting -- the Fun! Digital 320 is designed for taking photos outdoors or in brightly lit environments. Inadequate lighting can exaggerate camera movement and contribute to blurred, "muddied," or uncrisp images. * Lens condition -- Check the lens periodically for smudges. If necessary, wipe the lens clean with a soft, lint-free cloth. Do not use cleaning solutions or chemically treated tissues. * Enlarging images using software -- otherwise normal digital images can appear to become blurry and/or blotchy when over-enlarged in software. To see an image's "true" appearance, use the software's Zoom In or Zoom Out feature to view it at 100%.
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
