Question about Sony BRAVIA KDL-22EX310 22" LED TV 1366x768, 50 Hz, Freeview, HDTV, LED Backlight
Sony bravia 22EX320 reboots and blink 8 times
Hi, I'm from the Netherlands. My Sony Bravia KDL-22EX320 (bought august 2011 in Holland) reboots several times. After that the red led blinks 8 times. I tried the factory reset but it didn't work. Please help.
    Top Expert:
  • Sony Master
  • 76,237 Answers
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Magazine" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Posted on Apr 19, 2014
5 Suggested Answers
C-Dog
Carl Manaloto
  • 84 Answers
SOURCE: 6 red light blinks-possible thermal fuse prob.
You need the location of the part that's stamped on the board near where it was soldered in. And you need a soldering tool to resolder the new part in and cut the excess wire with cutters so you're not to short out the circuit.
C-Dog
Posted on Feb 10, 2008
ABRsvcs
  • 4234 Answers
SOURCE: Sony Bravia KDL-40W4500 turns off
This can indicate a problem with the high voltage circuits. Since this is a new set, it should still be under warranty. DO NOT open up the unit as that will void the warranty. Return the set or request warranty service. Note the 8 blinks when you request service as that should allow them to bring the correct replacement parts.
Keep us posted.
Dan
Posted on Jan 05, 2009
Anonymous
  • 53 Answers
SOURCE: 40xbr2 bravia kdl sony LCD tv. The screen shuts
Problems relating to the automatic turn on and turn off of a set like this usually point to the main board being an issue. For this set, I believe Sony refers to that board as the "AU" board.
It's probably not the G/Power Supply board, especially if it turns itself on. Power supplies will turn a set off, but rarely--rarely--turn itself on.
If there's no kind of extended warranty involved here,
you could be looking at $500.00 for parts and labor to repair this kind of problem.
As always, try any software/firmware updates Sony might have available on their website prior to pursuing a repair visit.
Posted on Jan 22, 2010
Jim Krause
  • 1779 Answers
SOURCE: HI JUST BOUGHT A KDL-32BX300
Defective set. I would return it immediately.
Posted on Nov 27, 2010
dcpelletier
SOURCE: I have a 2008 Sony
I have a 2008 Sony Bravia KDL-46W4100 that when I turn it on the red light blinks 14 times.
Please help me troubleshoot this problem so I can order the correct part to fix this television
Posted on Jan 01, 2011
13 Blinks Sony Bravia KDL-40V3000, Back Light Issue?
13 red flashing is backlight balance error bad lcd panel or inverter boards (common) or bal board on kdl-52v4100 only, replace inverter board usually then main logic board
Apr 12, 2018 | Sony Televison & Video
What's six red blinks at sony tv?
Hi, [Error code 6. LED flashes 6 times]. Malfunction of inverter or overcurrent protection....regards Sean
Jan 15, 2016 | Sony BRAVIA KDL-32BX330 32" 720p HDTV with...
Sony Bravia KDL-46W3000 - Shuts off after 30 sec followed up with 6 red blinks.Last 3 days back cover off has been working fine. What board should I be replacing?
Sony Bravia TV kdl- red blinking led light error codes ...
? 10:28
https://www.youtube.com/watch?v=0KGysXbxnaU
Mar 28, 2015 - Uploaded by Tampatec
Sony Bravia LCD TV KDL models red blinking led light error codes & possible ... with perfect picture, no warning signs and it just shuts off. is it that quick? ... with the following problem: I connect the power grid lights Standby red light. ... the title before deleting, it is very fast after that flashes Standby 6 times.Missing: 46w3000 ‎30
Nov 18, 2015 | Sony BRAVIA KDL-46W3000 Television
What does 4-blink error code indicate?
These may help - the first just tell what it is and which ICs maybe the problem (quite technical)
Solved Sony Bravia Blinking Code
Bravia KDL46EX720 Red LED blinks 4 times and TV wont turn on What is the...
or, in the last resort you could try Sony support, either to get a service manual, or to ask a technician. Don't be fobbed with an expensive answer as in one the examples above.
Support for LCD TV BRAVIA Sony
18.November.2015
Nov 14, 2015 | Sony KDL-46EX720 BRAVIA 46 Class LED 3D...
I have a 2011 Sony bravia LCD TV model kdl 40ex621....I hit power button and red led turns green then switches right back to red and blinks 4 times, I need to know what board to replace. Thank you!!
Hi Loren,
Timing control ( TCon) board seems to be the culprit in this case. Please check the connectors and the cables to and fro TCon before going for the replacement.
Good luck.
Apr 11, 2015 | Sony Televison & Video
Hey so my sony Bravia LCD 55" TV if blinking a red light 5 times and won't turn on...... any idea what I need to fix and how? Oh model # kdl-55ex640
HI
if your modal no is KDL-55EX640 & red light is blinking 5 times then your led panel is defective so please change your led panel in this case
Apr 09, 2015 | Sony Televison & Video
When I turn on my sony KDL-52W5100, its acting like its booting up (showing the sony and bravia)then the screen goes blank. Then the red light start blinking 6 time. what do I do/
Hi
there is a back light problem the connectors of back light are loosing so please go to your nearest Sony service center & solve the problem but if you know about led so remove the o cell & clean the connectors but if you are end user please don't open the led because the panel is thin
Dec 29, 2014 | Sony KDL-52W5100 TV
My sony bravia model number kdl 46ex723 blinks four times what that mean
Solution for Sony Bravia KDL 46EX723 blinking red light 8 times. Information below is from Sony online support, it worked for me:
Please disconnect the Internet connection from the TV and your TV will work fine.
We are suspecting a network outage issue on Sony device, we are currently investigating this issue. I am really sorry for the inconvenience caused.Unfortunately we don't have any ETA on this,I request you to try at a later time.
Nov 18, 2012 | Sony " 46"" Class - LED - 1080p - 120Hz -...
Sony BRAVIA KDL-22EX310 22" LED TV 1366x768, 50 Hz, Freeview, HDTV, LED Backlight Logo
314 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
