The computer won't see the card i took today on the card.
When I insert the card into the laptop slot for the card, it doesn't acknowledge having any pictures on the card at all. Is there something wrong with the card or laptop? Thank you.
i would suggest calling technical support to see if the sim card you are using is even compatible with your laptop, you should not be having this problem if it is.
Try downloading the current software for you model from the Canon site. You could try inserting the memory card into the card reader on your computer and if you get the same result then it would appear to be a software problem that you use to download. Sometime conflicts appear.
Try to insert the card first to your computer that has a memory card slot reader. If the computer did not recognize the card then the problem is the card already.
what device? is *********** board won't start? Or a hardware doesn't start like ram or your printer If the problem is your motherboard check all your hardwares and connectors like this:
If the motherboard won't start if you click the power button check the LED(the small light bulb on your motherboard) if its glowing. If not, check the connector of your power supply or check the power supply if its working by looking its fan if revolving.
If you push the button and there's a sign of power but didn't start up that will appear on your screen check the connection of your monitor screen to your desktop computer. If it's connected, remove your RAM from the motherboard and insert it to another memory slot to check if it's broken.
Last, if you push the power button and here 1 short beep but the boot screen didn't appeared from your screen check your graphic card. Remove the graphic card and re-insert it again to its graphic card slot and plug in your monitor connector to it. If it still remain that way, buy a new graphic card.
Insert your memory stick to your laptop, if your laptop has a memory stick slot or in the USB slot (if it is supported). If it doesn't have on you need a memory stick card reader. Insert your memory stick on a card reader then insert the card reader into the USB slot.
After that your laptop will prompt you and choose "view folder".
Now go to the folder where your pictures is located and choose the pictures you want to transfer and then right click on it and click "copy".
Go back to the folder of your memory stick, right click and then click "paste".
That should do it.
Thanks for using fixya!
Update me if you still have questions and let me know how I helped you.
regarding with the issue that you are having with your sony vaio card reader here are some things you can do
- try to perform a system restore and try to restore the computer to a date that the computer is working fine
- try to reinstall the driver for the memory stick pro card reader
- the website for the driver is www.esupport.sony.com
- as far as i understand your issue you are using the card reader port for the memory stick pro
hi, does your phone have a memory card? if yes, do these.. >>if the pictures is stored in your phone memory, then copy the pictures from your phone memory to your memory card. once copied, switch off your phone, remove your memory card, get your memory card adapter, insert memory card and insert it to your laptop sd reader slot and copy the files from your memory card to your laptop. if you use desktop and has no sd memory card reader slot, borrow memory card reader from a friend, connect it your computer, insert the your memory card from there and once read, copy the files to your computer. this also is applicable if you want to copy files from your computer to your phone. >>if it doesn't have, then, borrow a bluetooth dongle from a friend, pair it with your phone, and send the file from your phone, one after the other...
This may sound bad, but I promise it isn't. Have you tried removing the SD card with a small pair of needle nose pliers or even some twizzers? It sounds like the spring mechanism failed, so your only solution now is to pull it straight out, a little force and it should come right out. There are no pins to bend on an SD card.
The "odd shaped port" you are referring to is most likely:
The Express Card slot (replacing the slot known as “PC-Card” replacing the slot formerly known as “PCMCIA”) are the biggest standard slot on a laptop designed to handle stuff like wireless cellular modems with antenna and micro hard drives. Most people won’t ever use this slot, but it’s a lot faster than it’s old relatives now that it connects directly to PCI-Express. From: www.geek.com
Do NOT put your memory card from your computer into that slot. Since you have indicated that the USB cable connector option will not work, you will have to go out and buy a memory card reader that is compatible with you memory card. They are relatively inexpensive and easy to find at most electronics stores. Plug in the card reader (USB) and seat in your memory card and the OS of your laptop should detect the card and allow you to download the pictures.
