Were i will get drivers for -
LG Laptop-Xnote G1
Model-LGK1
Config-G1
Were i will get drivers for -LG Laptop-Xnote G1Model-LGK1Config-G1
Yes you can get this driver by login on lgservice.com
there you can see the option of support click on that
then you will be questioned what is your continent and country by defining this
you will see they asked you product select notebook
than they will ask you series select k1
than click on submit you can see the drivers whichever you want select it and download the driver after that you can setup it easily on your computer
if you can't get it ask me further on this mail id [email protected]
i will send you that web address on which you can download your drivers easily.
PLS SOME DEVICE DOSE NOT WORK ON MY LAPTOP LIKE MULTIMEDIA AUDIO CONTROLLER, NETWORK CONTROLLER, PCI BEIDGE, PCI MODEM, VIEO CONTROLLETR , VIDEO CONTROLLER(VGA COMPATIBLE)
I looked at the model number and ended up transposing it differently
here... LG is really tricky about their model numbers. It's very
difficult to find any information on these particular models. Isn't it?
The best information I could find on that laptop is that it is using the Intel Graphics Media Accelerator 900 chip. (GMA 900).
I found a page with the driver for the video I'll give you the link to
the main page. If you read the page, it will easily navigate you to
downloading the driver itself.
http://www.intel.com/products/chipsets/gma900/index.htm
If you are having trouble with the video driver, then I must assume
that you are also having a lack of drivers for everything else, too. I
can't help much without specific specifications for your other
devices. You should use some diagnostic software such as CPUz to find
out a bit more about your laptop. It should be able to tell you what
chipset it's using. It is very important to also install the chipset
drivers for your system. (It helps maintain stability of the system.)
CPUz identifies your processor, memory and chipset.
Find CPUz here: http://www.cpuid.com/cpuz.php
There is also a utility for identifying your chipset that Intel makes.
Find it here:
http://support.intel.com/support/chipsets/inf/sb/CS-009266.htm
Based on the specs I found from this series of LG laptops, I am also
going to assume that it's using the Intel Mobile 915 chipset.
Chipset Drivers (if it is the Mobile 915) are here:
http://support.intel.com/support/chipsets/sb/CS-020149.htm
If you do need the audio drivers and they are indeed RealTek AC'97, you can find those drivers here:
http://www.realtek.com.tw/downloads/downloadsView.aspx?Langid=1&PNid=23&PFid=23&Level=4&Conn=3&DownTypeID=3&GetDown=false#AC
I hope that helps you get it running correctly.
Cyryl
Does any one hav the mother board CD of LG Xnote G1 model K1 if any one is havind this can you pleasee send this cd image or other supporting files for LG Xnote G1 model K1 please please its urgent
I have Lg xnote G1-325LA2 & had similar problem. You can find all drives on the LG support site , choose the model as K1. If you can't locate it contact me and i'll send you the exact link.
SOURCE: DRIVERS FOR LG LPTOP XnoteG1
Click HERE to get software, drivers and manuals for your LG notebook.
hou to get diplay driver
no audio in the notebook,we want our multimedia audio controller for our LG X note G1
My LG Xnote G1 model K1 after formatted. I need drivers for the same. please help me what to do...
my original xnote g1 laptop driver cd has gone please help me
my sound driver is'nt working bcz of which i cant listen to audio sounds
we lost the installation cd or driver for model LGK1 config G1... Can somebody help us to check where we can get the program for that model and config... Thanks...
Thanks...
sound problem
PLS. CAN U GUYS HELP ME OUT WITH LGK1 DRIVERS.U CAN REACH ME ON MY E-MAIL.
i have just formated my laptop n i need it drivers
i need LG G1 Express Driver for Widows XP
where wil i get driver 4 lgk1 notebook...as i formatted it but i cant find the driuvers....
LGK1 LAPTOP DRIVERS
i want to LGK1 G1 driver cd so please provide the cd
thnks
i want all the driver
i want to Driver Softwares
i formatted my lg xnote g1,after this the sound is not coming
i have lost my recoery cd and is unable to download audio driver pls help me with process
sir, where i ll get LG F1 (X NOTE FD) LAPTOP wifi drives
